查看: 3330|回复: 4
cadence中的dracula不能用,请问dracula的设置在哪里
发表于 2013-5-24 17:39:03 | 显示全部楼层 |阅读模式
cadence中的dracula不能用,请问dracula的设置在哪里?在用dracula做DRC时发现如下错误,请大侠帮忙?不知道到底为什么dracula不能用?
发表于 2013-6-28 17:40:14 | 显示全部楼层
command file 要是unix 文字格式
試試  dos2unix 指令
发表于 2015-8-10 19:32:28 | 显示全部楼层
这个问题解决了吗?
 楼主| 发表于 2015-8-11 09:12:11 | 显示全部楼层
回复 3# DC-DC
这个应该是目录下的.bashrc或者.cshrc设置没有写对,先看下你用的是哪种,然后到设置对就可以了!
发表于 2015-9-23 15:59:14 | 显示全部楼层
回复 4# 蓝风紫心
您好!非常感谢。我用的是.bashrc,dracula在soft/IC5141USR6/tools/目录下,但还是同样的问题,能否帮我看看问题在哪?谢谢!
   # .bashrc
# User specific aliases and functions
# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
export PATH=/soft/bin:/soft:/sbin:/usr/kerberos/sbin:/usr/kerberos/bin:/bin:/usr/bin:/usr/bin/X11:/usr/local/bin:/usr/bin:/usr/X11R6/bin:./
export LD_LIBRARY_PATH=./
export CVSROOT=:ps
#IC5141USR6
export CDS_LIC_FILE=/soft/bin/license.dat
export CDSDIR=/soft/IC5141USR6/tools.lnx86
export CDS_ROOT=/soft/IC5141USR6
export CDS_INST_DIR=$CDS_ROOT
export CDS_Netlisting_Mode=Analog
export XKEYSYMDB=$CDS_ROOT/share/cdssetup/tdmX11/XKeysymDB
export XNLSPATH=$CDS_ROOT/share/cdssetup/tdmX11/nls
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/soft/IC5141USR6/tools.lnx86/lib
PATH=$PATHCDSDIR/bin
PATH=$PATHCDSDIR/dfII/bin
PATH=$PATHCDSDIR/SKILL06.00/context
PATH=$PATH:$CDSDIR/SKILL06.10/context
PATH=$PATH:$CDSDIR/dracula/bin
PATH=$PATH:$CDSDIR/plot/bin
PATH=$PATH:/usr/local/netscape
PATH=$PATH:/usr/bin
#Cadence SOC
export SOC=/soft/SOC08.10
PATH=$PATH:$SOC/tools/bin:$SOC
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SOC/tools/lib
#Synosys Formality
export FM_HOME=/soft/fm2008.03sp3
PATH=$PATH:$FM_HOME/linux/fm/bin
#Synosys PrimeTime
export PRIMETIME_HOME=/soft/pts2009.06
PATH=$PATH:$PRIMETIME_HOME/linux/syn/bin
export DC_HOME=/soft/dc2009.06sp1
PATH=$PATH:$DC_HOME/bin
#Synosys PrimeTime
export PRIMETIME_HOME=/soft/hspice2008.03sp1
PATH=$PATH:$PRIMETIME_HOME/hspice/bin
#Mentor Calibre2010.2
export  MGC_HOME=/soft/ixl_cal_2010.2_38.23
PATH=$PATH:$MGC_HOME/bin
#LICENSE FILE
LM_LICENSE_FILE=27000@linux:37000@linux
export LM_LICENSE_FILE
GMT+8, 2025-12-22 19:58 , Processed in 0.018291 second(s), 5 queries , Gzip On, Redis On.
