查看: 3905|回复: 1
[求助] Goden RTL怎么解释
发表于 2013-5-20 21:17:59 | 显示全部楼层 |阅读模式
在FPGA设计中,经过功能仿真的RTL代码被称作Golden RTL,这两种RTL有什么不同?求详解
发表于 2013-5-21 16:16:36 | 显示全部楼层
Golden RTL Usually design process involves lot of changes and ECOs (Engineering Change Order) where the code will be modified. Once all these modifications are done and the netlist is finalised to be processed for next stage, it\'s called \"Golden RTL\" which usually won\'t have much architectural changes.
GMT+8, 2025-12-16 11:32 , Processed in 0.276674 second(s), 5 queries , Gzip On, Redis On.
