查看: 4078|回复: 0
[求助] perl xml-parser版本不匹配问题
发表于 2013-5-17 14:01:13 | 显示全部楼层 |阅读模式
在网上下载了一个spec2reg的perl脚本,运行后上报下面的错误,在网上搜了好久也没找到解决办法,哪位帮忙看下怎么解决?
[cy@xichi-ws ~]>svfSRT
XML:arser::Expat object version 2.36 does not match bootstrap parameter 2.34 at /usr/lib64/perl5/DynaLoader.pm line 223.
Compilation failed in require at /usr/eda/pw_spec2reg-1_0/bin/../lib/external/lib/perl5/XML/Parser.pm line 14.
BEGIN failed--compilation aborted at /usr/eda/pw_spec2reg-1_0/bin/../lib/external/lib/perl5/XML/Parser.pm line 18.
Compilation failed in require at /usr/eda/pw_spec2reg-1_0/bin/../lib/external/lib/perl5/XML/Twig.pm line 87.
BEGIN failed--compilation aborted at /usr/eda/pw_spec2reg-1_0/bin/../lib/external/lib/perl5/XML/Twig.pm line 87.
Compilation failed in require at /usr/eda/pw_spec2reg-1_0/bin/svfSRT.pl line 49.
BEGIN failed--compilation aborted at /usr/eda/pw_spec2reg-1_0/bin/svfSRT.pl line 49.
GMT+8, 2025-12-16 16:02 , Processed in 0.030081 second(s), 6 queries , Gzip On, Redis On.
