查看: 4702|回复: 3
[求助] ISE MAP时出错?错误信息如下:
发表于 2013-5-14 13:41:21 | 显示全部楼层 |阅读模式
Pack:1107 - Pack was unable to combine the symbols listed below into a single IOB component because the site type selected is not compatible. The buffer lb_to_sram_inst/idt_r_data_0_IOBUF/OBUFT can not merge with signal idt_r_data<0>.  The signal has a NOMERGE property.
发表于 2013-5-18 08:13:39 | 显示全部楼层
双向IO?
 楼主| 发表于 2013-5-22 10:30:09 | 显示全部楼层
对,双向IO,提示这个错误
发表于 2016-3-28 18:59:21 | 显示全部楼层
请问后来你解决了吗?
GMT+8, 2025-12-27 10:42 , Processed in 0.042522 second(s), 6 queries , Gzip On, Redis On.
