查看: 9144|回复: 4
[求助] 数字后端设计ICC问题
发表于 2013-5-8 21:37:54 | 显示全部楼层 |阅读模式
请问route_fp_proto是检查布线能力的命令吗??附件中是我运行完这个命令后的结果,如何来查看它的结果啊?????另外extract_rc命令是用来做何用的??
忘各位指点哦,谢谢!
结果.doc
34 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-5-8 23:04:36 | 显示全部楼层
还是把word里的内容复制粘贴进来吧,方便大家查看
 楼主| 发表于 2013-5-9 16:50:11 | 显示全部楼层
回复 1# sunny_yangfeng
ok,word里的结果如下:请指点一二,谢谢啦
icc_shell> route_fp_proto -effort medium
Begin global routing.
Reading database ...
Using [3 x 3] Fat Wire Table for MET1
Using [3 x 3] Fat Wire Table for MET2
Using [3 x 3] Fat Wire Table for MET3
Select via(VIA23) as the default forlayer(VI2)
Select via(VIA12) as the default forlayer(VI1)
**** WARNING:no default via for layer(CONT)
**** WARNING:can't find via for stack ruleVI1:CONT
**** WARNING:can't find via for stack ruleCONT:VI1
# Masters = 20 , # Instances = 665 , # Nets= 787
**** WARNING:Cannot find any fat via for(VI2)
Net [clk_in] with 221 ports!
Constructing data structure ...
Number of plan groups = 0
Number of voltage areas = 0
user unit = 1000 db unit.
db min Grid = 10 db unit.
Design Bounding Box (0.00 0.00) (530.50521.80)
Number of routing layers = 3.
track info for layer(MET1):
Number of X routing tracks = 355.
X Track min 0.10 max 530.40, Ave. trackdist = 1.50
Number of Y routing tracks = 454.
Y Track min 0.55 max 521.50, Ave. trackdist = 1.15
track info for layer(MET2):
Number of Y routing tracks = 715.
Y Track min 0.55 max 521.50, Ave. trackdist = 0.73
track info for layer(MET3):
Number of Y routing tracks = 275.
Y Track min 0.55 max 521.50, Ave. trackdist = 1.90
Creating uniform X GGrids ...
Creating uniform Y GGrids ...
Number of X global grids = 25.
Number of Y global grids = 24.
X global grid min 0.00 max 531.50, Ave.ggrid dist = 22.14
Y global grid min 0.00 max 522.80, Ave.ggrid dist = 22.73
Number of instances = 665.
Number of signal/clock nets = 785.
Number of net ports = 2611.
Average number of ports per net = 3.33
Largest net clk_in has 221 ports.
Number of GCells = 1656.
VR: Init Virtual Routing - Level 1
VR: ignore voltage areas
VR: Virtual Routing Completed
Number of nets to route = 785.
Begin Initial routing ...
Initial routing completed.
Initial. Routing result:
Initial. Both Dirs: Overflow = 2 Max = 1GRCs = 2 (0.18%)
Initial. H routing: Overflow = 0 Max = 0GRCs = 0 (0.00%)
Initial. V routing: Overflow = 2 Max = 1 (2GRCs) GRCs = 2 (0.18%)
Initial. MET1     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
Initial. MET2     : Overflow = 2 Max = 1 (2 GRCs) GRCs = 2(0.36%)
Initial. MET3     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
Initial. Total wire length = 58706.85
Initial. Layer MET1 wire length = 1290.22
Initial. Layer MET2 wire length = 31908.80
Initial. Layer MET3 wire length = 25507.83
Initial. Via VIA12 count = 2657
Initial. Via VIA23 count = 1334
Begin Rerouting ...
Begin Phase 1 ...
phase1. Routing result:
phase1. Both Dirs: Overflow = 0 Max = 0GRCs = 0 (0.00%)
phase1. H routing: Overflow = 0 Max = 0GRCs = 0 (0.00%)
phase1. V routing: Overflow = 0 Max = 0GRCs = 0 (0.00%)
phase1. MET1     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
phase1. MET2     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
phase1. MET3     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
phase1. Total wire length = 58707.15
phase1. Layer MET1 wire length = 1290.22
phase1. Layer MET2 wire length = 31840.10
phase1. Layer MET3 wire length = 25576.83
phase1. Via VIA12 count = 2656
phase1. Via VIA23 count = 1335
Phase 1 completed.
Congestion is minimized. Quit rerouting.
Begin Phase 2 ...
phase2. Routing result:
phase2. Both Dirs: Overflow = 0 Max = 0GRCs = 0 (0.00%)
phase2. H routing: Overflow = 0 Max = 0GRCs = 0 (0.00%)
phase2. V routing: Overflow = 0 Max = 0GRCs = 0 (0.00%)
phase2. MET1     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
phase2. MET2     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
phase2. MET3     : Overflow = 0 Max = 0 GRCs = 0 (0.00%)
phase2. Total wire length = 58707.15
phase2. Layer MET1 wire length = 1290.22
phase2. Layer MET2 wire length = 31840.10
phase2. Layer MET3 wire length = 25576.83
phase2. Via VIA12 count = 2656
phase2. Via VIA23 count = 1335
Phase 2 completed.
Rerouting completed.
Writing results to database ...
Deleting previous global routing.
[ End of Global Routing] CPU =   0:00:00, gr_data VM =        4 M
                   Elapsed =    0:00:01, total   VM =     167 M
Global routing completed.
1
发表于 2016-3-31 09:59:04 | 显示全部楼层
extract_rc命令是用来提取寄生参数的
发表于 2019-3-12 14:26:27 | 显示全部楼层
回复 3# sunny_yangfeng
   顶一下,我也出现了这样的问题,暂时无法解决,这会导致后面的PG mesh无法创建。大量的warning会出现
GMT+8, 2025-12-23 22:59 , Processed in 0.038729 second(s), 7 queries , Gzip On, Redis On.
