查看: 3542|回复: 8
[招聘] 找FPGA----千军易得,一将难求啊
发表于 2013-5-8 10:09:57 | 显示全部楼层 |阅读模式
Senior FPGA Engineer
Responsibilities
As a Senior FPGA Engineer, you will be responsible for specification, FPGA logic design, simulation, synthesis, timing analysis, integration and lab debug. You will participate in verification, board design, diagnostics and/or firmware integration. The job also entails mentoring junior engineers and extending your engineering capacity through them.
Requirements
§ Bachelor/Master’s degree in Electrical Engineering
§ At least 3 years of direct FPGA design experience
§ Solid understanding of FPGA tools
§ Experience developing FPGA RTL code and simulation test benches using VHDL/Verilog.
§ Experience developing simulation test benches § Experience with code-coverage tools
§ Design experience with multi-gigabit serial I/O a MUST
§ Experience with one or more scripting languages for FPGA design/verification process automation
§ Experience with command-line automation of FPGA design/synthesis/verification process
§ Ability to debug complex architectural designs on simulation and in real hardware.
§ Ability to read PCB schematics and device datasheets for design review and debug
§ Ability to read PCB layout data files to probe and debug FPGA interfaces
§ Strong laboratory experience using scopes and logic analyzers
§ Candidates with fibre channel or networking product design experience a strong plus
§ Good English reading skills required
高级FPGA工程师
工作职责:
负责相关规格的制定,FPGA逻辑的设计,能进行代码的仿真,综合,时序分析和实验室调试。将参与产品的验证,板级设计,调试以及软件的整合。作为高级工程师,能带领下面的工程师开展工作和共同进步。
职位要求:
1.
电子信息类本科/硕士学位毕业
2.
良好的工作态度和团队协作意识,认真负责,自我激励
3.
至少3年FPGA设计经验
4.
熟练使用FPGA设计相关工具
5.
FPGA RTL code 经验和 VHDL/Verilog test bench的编写经验
6.
大型项目的test bench 的编写经验
7.
有使用code-coverage 工具的相关经验
8.
必须有过千兆串行接口的设计经验
9.
掌握一种以上的FPGA设计/验证的自动脚本语言
10.
复杂系统的设计,调试,仿真能力,包括代码级和实际硬件。
11.
能看懂线路图和PCB,相关元件的datasheet,并参与检查和调试
12.
能看懂PCB文档,对FPGA的相关引脚进行实际信号的测试
13.
能熟练使用示波器和逻辑分析仪
14.
光通讯和网络产品的相关设计经验优先
15.
良好的英语阅读能力
感兴趣的可以站内M我,至少3年相关经验,其他的要求可以适当降低。
发表于 2013-5-8 11:05:26 | 显示全部楼层
工作地点?
发表于 2013-5-8 13:55:00 | 显示全部楼层
看起来还行,现在专门的fpga岗位似乎很少
发表于 2013-5-8 15:07:26 | 显示全部楼层
你这是什么行业??
 楼主| 发表于 2013-5-8 16:22:14 | 显示全部楼层
哦,解释下。
工作地点在上海漕河泾开发区。
至于要求,那是希望,人无完人嘛,所以有些是可以降低的。但是如果是高工,那么必须要带过项目,因为这是他过来后的基本工作啊;如果是一般工程师有3年工作经验的话,那么要求能够独挡一面,这个要求也不过分吧。
我们是通信行业的,所以最好是有过相关背景的比较好,做过交换机就更加适合了。
发表于 2013-5-8 16:53:05 | 显示全部楼层
可惜你在上海,
而我在深圳。。。
其他就不说了
发表于 2013-5-8 22:02:13 | 显示全部楼层
有兴趣请联系:QQ1634696325
发表于 2013-5-9 09:15:44 | 显示全部楼层
是不是nsn,其实总结起来也就几点,写的比较繁杂。
具备比较规范的FPGA设计流程.(这条就应该包括testbench,coverage,FPGA仿真debug),一般的不怎么规范的小公司是不做流程的,更别说是coverage
 楼主| 发表于 2013-5-9 15:47:41 | 显示全部楼层
留个邮箱吧。本来以为没几个人的,想不到还是不少人感兴趣。
junping.li@saicocch.com
站内M我的我都一一回了。
GMT+8, 2025-12-25 10:10 , Processed in 0.023279 second(s), 7 queries , Gzip On, Redis On.
