查看: 4023|回复: 2
ubuntu 下安装cadence 615求助
发表于 2013-4-29 11:35:59 | 显示全部楼层 |阅读模式
按照http://bbs.eetop.cn/viewthread.php?tid=387531 在ubuntu13.04 上安装完了
安装完后,运行,出现以下错误,求大神帮我找找原因啊,不胜感激!!
XXX@XXX-ThinkPad-T420:~$ virtuoso:   ERROR: The OA2.2 library directory (ERROR: oaGetLibPath cannot be executed because the /home/linbin/eda/IC615/oa_v22.41.004/bin/linux_rhel4O_gcc44x_32/opt directory does not exist.
  Verify that the OA_BIT environment variable is set correctly or unset this variable.
  Verify that the OA_MODE environment variable is set correctly or unset this variable.) does not seem to exist.
virtuoso:    INFO: You have OA_UNSUPPORTED_PLAT set to "linux_rhel4O_gcc44x" in your environment:
virtuoso:          check that the value provided correspond to a valid OA platform.
virtuoso:          If this value is correct, check your OA installation.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2013-4-29 14:22:03 | 显示全部楼层
是linux_rhel40_gcc44x不是linux_rhel4O_gcc44x
 楼主| 发表于 2013-4-30 05:25:35 | 显示全部楼层
回复 2# yulizi
大哥,我错了。最近恍惚的不行,这中错误都没发现。。。惭愧啊,还是谢谢你, 问题解决。
GMT+8, 2025-12-25 10:49 , Processed in 0.012911 second(s), 3 queries , Gzip On, Redis On.
