查看: 4716|回复: 7
[资料] 高清版高数字设计和完整数字设计
发表于 2013-4-19 10:50:50 | 显示全部楼层 |阅读模式
SI经典名着之一 黑宝书——高速数字设计。
完整数字设计目录:
PART 1 Digital Fundamentals
Chapter I Digital Logic
1.1 Boolean Logic / 3
1.2 Boolean Manipulation / 7
1.3 The Karnaugh map ! 8
1.4 Binary and Hexadecimal Numbering / I0
1.5 Binary Addition ! 14
1.6 Subtraction and Negative Numbers / 15
1.7 Multiplication and Division / 17
1.8 Flip-Flops and Latches / 18
1.9 Synchronous Logic / 21
1.10 Synchronous Timing Analysis / 23
1.11 ClockSkew / 25
1.12 Clock Jitter / 27
1.13 Derived Logical Building Blocks / 28
Chapter 2 Integrated Circuits and the 7400 Logic Families
2.1 The Integrated Circuit / 33
2.2 IC Packaging ! 38
2.3 The 7400-Series Discrete Logic Family / 41
2.4 Applying the 7400 Family to Logic Design / 43
2.5 Synchronous Logic Design with the 7400 Family / 45
2.6 Common Variants of the 7400 Family / 50
2.7 Interpreting a Digital IC Data Sheet / 51
Chapter 3 Basic Computer Architecture
3.1 The Digital Computer / 56
3.2 Microprocessor Internals / 58
3.3 Subroutines and the Stack ! 60
3.4 Reset and Interrupts / 62
3.5 Implementation of an Eight-Bit Computer / 63
3.6 Address Banking / 67
3.7 Direct Memory Access / 68
3.8 Extending the Microprocessor Bus / 70
3.9 Assembly Language and Addressing Modes / 72
Chapter 4 Memory
4.1 Memory Classifications / 77
4.2 EPROM / 79
4.3 Flash Memory i 81
4.4 EEPROM / 85
4.5 Asynchronous SRAM / 86
4.6 Asynchronous DRAM / 88
4.7 Multiport Memory / 92
4.8 The FIFO / 94
Chapter 5 Serial Communications
5.1 Serial vs. Parallel Communication / 98
5.2 The UART / 99
5.3 ASCII Data Representation / 102
5.4 RS-232 / 102
5.5 RS-422 / 107
5.6 Modems and Baud Rate / 108
5.7 Network Topologies / 109
5.8 Network Data Formats / 110
5.9 RS-485 / 112
5.10 A Simple RS-485 Network / 114
5.11 Interchip Serial Communications / 117
Chapter 6 Instructive Microprocessors and Microcomputer Elements
6.1 Evolution / 121
6.2 Motorola 6800 Eight-bit Microprocessor Family / 122
6.3 Intel 8051 Microcontroller Family / 125
6.4 Microchip PIC Microcontroller Family / 131
6.5 Intel 8086 16-Bit Microprocessor Family / 134
6.6 Motorola 68000 16/32-Bit Microprocessor Family / 139
PART 2 Advanced Digital Systems
Chapter 7 Advanced Microprocessor Concepts
7.1 RISC and CISC / 145
7.2 Cache Structures / 149
7.3 Caches in Practice / 154
7.4 Virtual Memory and the MMU / 158
7.5 Superpipelined and Superscalar Architectures / 161
7.6 Floating-Point Arithmetic / 165
7.7 Digital Signal Processors / 167
7.8 Performance Metrics / 169
Chapter 8 High-Performance Memory Technologies
8.1 Synchronous DRAM / 173
8.2 Double Data Rate SDRAM / 179
8.3 Synchronous SRAM / 182
8.4 DDR and QDR SRAM / 185
8.5 Content Addressable Memory / 188
Chapter 9 Networking
9.1 Protocol Layers One and Two / 193
9.2 Protocol Layers Three and Four / 194
9.3 Physical Media / 197
9.4 Channel Coding / 198
9.5 8B10B Coding ! 203
9.6 Error Detection / 207
9.7 Checksum / 208
9.8 Cyclic Redundancy Check / 209
9.9 Ethernet / 215
Chapter 10 Logic Design and Finite State Machines
10.1 Hardware Description Languages / 221
10.2 CPU Support Logic / 227
10.3 Clock Domain Crossing / 233
10.4 Finite State Machines / 237
10.5 FSM Bus Control / 239
10.6 FSM Optimization / 243
10.7 Pipelining / 245
Chapter 11 Programmable Logic Devices
11.1 Custom and Programmable Logic / 249
11.2 GALs and PALs / 252
11.3 CPLDs / 255
11.4 FPGAs / 257
PART 3 Analog Basics for Digital Systems
Chapter 12 Electrical Fundamentals
12.1 Basic Circuits / 267
12.2 Loop and Node Analysis / 268
12.3 Resistance Combination / 271
12.4 Capacitors / 272
12.5 Capacitors as AC Elements / 274
12.6 Inductors / 276
12.7 Nonideal RLC Models / 276
12.8 Frequency Domain Analysis / 279
12.9 Lowpass and Highpass Filters / 283
12.10 Transformers / 288
Chapter 13 Diodes and Transistors
13.1 Diodes / 293
13.2 Power Circuits with Diodes / 296
13.3 Diodes in Digital Applications / 298
13.4 Bipolar Junction Transistors / 300
13.5 Digital Amplification with the BJT / 301
13.6 Logic Functions with the BJT / 304
13.7 Field-Effect Transistors / 306
13.8 Power FETs and JFETs / 309
Chapter 14 Operational Amplifiers
14.1 The Ideal Op-amp / 311
14.2 Characteristics of Real Op-amps / 316
14.3 Bandwidth Limitations / 324
14.4 Input Resistance / 325
14.5 Summation Amplifier Circuits / 328
14.6 Active Filters / 331
14.7 Comparators and Hysteresis / 333
Chapter 15 Analog Interfaces for Digital Systems
15.1 Conversion between Analog and Digital Domains / 339
15.2 Sampling Rate and Atiasing / 341
15.3 ADC Circuits / 345
15.4 DAC Circuits / 348
15.5 Filters in Data Conversion Systems / 350
PART 4 Digital System Design in Practice
Chapter 16 Clock Distribution
16.1 Crystal Oscillators and Ceramic Resonators / 355
16.2 Low-Skew Clock Buffers / 357
16.3 Zero-Delay Buffers: The PLL / 360
16.4 Frequency Synthesis / 364
16.5 Delay-Locked Loops / 366
16.6 Source-Synchronous Clocking / 367
Chapter 17 Voltage Regulation and Power Distribution
17.1 Voltage Regulation Basics / 372
17.2 Thermal Analysis / 374
17.3 Zener Diodes and Shunt Regulators / 376
17.4 Transistors and Discrete Series Regulators / 379
17.5 Linear Regulators / 382
17.6 Switching Regulators / 386
17.7 Power Distribution / 389
17.8 Electrical Integrity / 392
Chapter 18 Signal Integrity
18.1 Transmission Lines / 398
18.2 Termination / 403
18.3 Crosstalk / 408
18.4 Electromagnetic Interference / 410
18.5 Grounding and Electromagnetic Compatibility / 413
18.6 Electrostatic Discharge / 415
Chapter 19 Designing for Success
19.1 Practical Technologies / 420
19.2 Printed Circuit Boards / 422
19.3 Manually Wired Circuits / 425
19.4 Microprocessor Reset / 428
19.5 Design for Debug / 429
19.6 Boundary Scan / 431
19.7 Diagnostic Software / 433
19.8 Schematic Capture and Spice / 436
19.9 Test Equipment / 440
Appendix A Further Education
发表于 2013-4-19 11:46:04 | 显示全部楼层
你发了个啥?
发表于 2014-9-8 00:59:16 | 显示全部楼层
Nice~~~
发表于 2015-1-6 16:12:06 | 显示全部楼层
怎么没下载呀
发表于 2015-1-7 10:34:53 | 显示全部楼层
忽悠来了啊
发表于 2015-8-11 22:12:03 | 显示全部楼层
是压根没有链接吗?还是失效了!
发表于 2017-2-22 22:48:22 | 显示全部楼层
没有连接吗
发表于 2024-9-9 10:32:38 | 显示全部楼层
没有连接吗
GMT+8, 2025-12-28 09:46 , Processed in 0.026282 second(s), 8 queries , Gzip On, Redis On.
