查看: 2447|回复: 5
[求助] 边界扫描和芯片内部全扫描是什么关系?
发表于 2013-4-10 12:03:06 | 显示全部楼层 |阅读模式
RT
两者完成的测试任务是独立的还是有交集的?边界扫描不是也能测试芯片内部么?另外,如果要用JTAG连接内部完整扫描链,在DC中应该怎样设置?
发表于 2013-4-11 17:01:05 | 显示全部楼层
同问!!!
发表于 2013-4-11 17:26:01 | 显示全部楼层
是独立的吧,边界扫描是PCB的标准。全扫描是芯片内部的DFT方法。
对它们之间的接口方式了解不多,搭车盼高人解答!
发表于 2013-6-18 20:43:57 | 显示全部楼层
Boundary scan enables board-level testing by providing direct access to the input and
output pads of the integrated circuits on a printed circuit board. Boundary scan modifies the
I/O circuitry of individual ICs and adds contro l logic so the input and output pads of every
boundary scan IC can be joined to form a board-level serial scan chain.
发表于 2013-6-18 20:47:29 | 显示全部楼层
The boundary-scan technique uses the serial scan chain to access the I/O ports of chips on
a board.
发表于 2014-2-20 14:19:01 | 显示全部楼层
有懂的人讲的明白些吧
GMT+8, 2025-12-26 06:34 , Processed in 0.018211 second(s), 5 queries , Gzip On, Redis On.
