Job Description:
1. The Application Engineer will need to ready to support OEM/ODM manufacturers for design support and resolved raised technical issued.
2. The candidate need to excises good technical practice and able to perform first line technical support into circuit level and component level.
3. Reporting to Application Manager and required to travel to US for 1-2 time per year when is needed.
REQUIREMENTS
1) BSEE/MSEE with a minimum of 3 to 5 years of switch mode power supply design experience in an MNC company environment.
2) Strong analytical skills and hands-on design experience are a must.
3) Knowledge in SMPS from Dual/Single FET forward, Flyback, SR is needed. Knowledge in LLC will be an added advantage.
4) Good communication skills.
5) Moderately fluent English (reading, writing, and speaking) is required.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”或扫描以上二维码即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!) |
