查看: 3423|回复: 0
[求助] Expect脚本嵌套
发表于 2013-4-6 04:09:04 | 显示全部楼层 |阅读模式
各位大神,我近日在做一个expect脚本,需求如下:
ssh进入一台机器,然后在那台机器上运行ping来测试端口
Codes:
proc ssh {} {
    global DST_IP
    global PSWD
    global PING_IP
    spawn ssh $DST_IP
    expect {
        -re ".*password.*" {
            send "$PSWD\r"
    expect {
        "Permission denied, please try again" {
            puts "\033\[31m>>>>>>>>>>>Permission Denied, please double check your PASSWORD"
            exit
        -re ".*Last login" {
#            interact
            exec "hostname"
            expect  {
                -ex "testbench" {
                    puts "\033\[32m>>>>>>>>>>>>>>Login Successfully!"
                    #            ping
                    spawn ping $PING_IP -c 10
                    expect  {
                        -re "\[\r\n]+.*10 packets transmitted" {
                            if { $expect_out(1,string) == "10" } {
                                puts "Ping is Fine!"
                            } else {
                                puts "Ping is failed!"
                        -re "\[\r\n].*Unreachable" {
                            puts "\033\[31m$PING_IP is Unreachable"
                            puts "\033\[30m\n"
                    exit
                    #    exit
                eof {
                    puts "\033\[31m>>>>>>>>>>>>>>>>Login Failed"
                   # exit
                timeout {puts "No response!"}
        eof {
    exit
红色部分总是在我当前机器上执行,而不是在我ssh进去的机器上执行,请问改如何实现?
谢谢!
GMT+8, 2025-12-29 15:01 , Processed in 0.160795 second(s), 5 queries , Gzip On, Redis On.
