查看: 29873|回复: 30
[求助] 请问ADE中Save Opions “allpub” 和 "lvlpub"表示什么意思?
发表于 2013-3-26 15:03:40 | 显示全部楼层 |阅读模式
请问ADE中Save Opions “allpub” 和 "lvlpub"表示什么意思? 谢谢!
发表于 2013-3-26 19:18:17 | 显示全部楼层
allpub貌似是全部保存,lvlpub等达人补充
 楼主| 发表于 2013-3-26 20:24:25 | 显示全部楼层
allpub 和 all 又有什么区别呢?
发表于 2013-3-26 20:47:10 | 显示全部楼层
这个问题从来没有人给我说清楚过
ADE手册里面也是含糊其辞的
 楼主| 发表于 2013-3-27 16:33:36 | 显示全部楼层
回复 1# microstudent
    自己顶下
发表于 2013-4-10 10:56:35 | 显示全部楼层
回复 4# ericking0
all 和 allpub 包括电流吗?
发表于 2013-4-10 11:26:09 | 显示全部楼层
回复 1# microstudent
    这个问题真的没有文档么?看看“Virtuoso Spectre Circuit Simulator and Accelerated Parallel Simulator User
Guide”,就会明白了
回复 支持 0 反对 1
发表于 2013-4-10 11:31:38 | 显示全部楼层
回复 4# ericking0
    那是因为你看的文档不对。Virtuoso Spectre Circuit Simulator and Accelerated Parallel Simulator User
Guide
回复 支持 0 反对 1
 楼主| 发表于 2013-4-10 13:33:21 | 显示全部楼层
回复 7# question23
    谢谢,我查到了,在spectre user guide里也有,我把摘抄在下边,方便大家查。
lvlpub Saves all signals that are normally useful up to nestlvl deep in the subcircuit hierarchy. This option is equivalent to allpub for subcircuits. Normally useful signals include shared node voltages and currents through voltage sources and iprobes.
allpub Saves only signals that are normally useful. Normally useful signals include shared node voltages and currents through voltage sources and iprobes.
回复 支持 10 反对 0
发表于 2013-4-10 15:13:41 | 显示全部楼层
The save Parameter Options
The following table shows the possible settings for the save parameter:
Setting Action
none Does not save any data (currently does save one node chosen at random).
selected Saves only signals specified with save statements. This is the default
setting.
lvl Saves all signals up to nestlvl deep in the subcircuit hierarchy. This
option is relevant for subcircuits.
all Saves all signals.
Use lvl or all (instead of lvlpub or allpub) to include internal node voltages and
currents through other components that compute current.
Use lvlpub or allpub to exclude signals at internal nodes on devices (the internal collector,
base, emitter on a BJT, the internal drain and source on a FET, etc). lvlpub and allpub
also exclude the currents through inductors, controlled sources, transmission lines,
transformers, etc.
Note: Setting the save parameter value to selected without any save statements in the
netlist is not equivalent to specifying no output. Currently, the Spectre simulator saves all
circuit nodes and branch currents with this combination of settings. This might change in
future releases of the Spectre simulator.
回复 支持 19 反对 2
GMT+8, 2025-12-23 17:36 , Processed in 0.024001 second(s), 3 queries , Gzip On, Redis On.
