查看: 13812|回复: 7
[求助] 这个错误什么意思
发表于 2013-3-20 19:52:10 | 显示全部楼层 |阅读模式
下面是我的代码,一运行就出现Error (10200): Verilog HDL Conditional Statement error at test2.v(34): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct这个错误,这是什么意思?
module hm(clk,rst_n,data,pulse,key/*,load*/);
input clk,rst_n,key;
input [7:0] data;
output pulse/*,load*/;
reg [7:0] count;
reg pulse;
reg clk_1;
reg [4:0] a;
always @(posedge clk or negedge rst_n)
  begin
   if(~rst_n)
     begin
          clk_1=0;
          a<=5'd0;
        end
      else
        if(a==5'd16)
          begin
            a<=5'd0;
            clk_1=~clk_1;
          end
         else
           a<=a+5'd1;
   end
always @(posedge clk_1 or negedge rst_n)
  begin
       if(~rst_n)
         begin
           count<=0;
           pulse<=0;
         end
       else
         count<=data;
           if(key==0)
              begin
                pulse<=1;
                count<=count-8'd1;
                  if(count==8'd0)
                    begin
                      pulse<=0;
                      count<=8'd0;
                         if(pulse==0)
                           begin
                             count<=data;
                           end
                     end
                end
   end
endmodule
发表于 2013-3-20 22:20:39 | 显示全部楼层
最好把行号也标上,比较好找错误!
发表于 2013-3-21 01:54:51 | 显示全部楼层
else
count<=data;
if(key==0)
这里的else后面缺了一个begin.
发表于 2013-3-21 10:14:05 | 显示全部楼层
你得把代码格式规范下,根据报错行数和报错内容找问题。
 楼主| 发表于 2013-3-21 19:24:32 | 显示全部楼层
回复 4# rdl890208
    你好,这个报错的地方是34行,if(key==0)的这个语句
发表于 2013-3-22 19:29:59 | 显示全部楼层
else 下面少了begin...end  建议代码规范
发表于 2018-8-7 13:22:53 | 显示全部楼层
It is good! Thanks for the sharing!
发表于 2018-8-7 13:24:55 | 显示全部楼层
GMT+8, 2025-12-20 11:08 , Processed in 0.021224 second(s), 4 queries , Gzip On, Redis On.
