查看: 2990|回复: 1
[求助] signoff_opt出错【已解决】
发表于 2013-3-20 19:51:52 | 显示全部楼层 |阅读模式
用ICC做后端,run_signoff调用PT与StarRC也没问题。就是到signoff_opt出错。
icc_shell> signoff_opt
Error: This site is not licensed for 'Galaxy-AdvOpt'. (SEC-51)
难道需要更高端的license才能用signoff优化功能么?
 楼主| 发表于 2013-3-24 07:59:09 | 显示全部楼层
联系过synopsys,他们给了这样的回信:
As I further confirmed, starting from ICC 2012.06-XX versions, signoff_opt requires LCA keys, as it is recommended to use the command "focal_opt" instead, and in future the command would be obsolete.
So can you please guide the users to start trying the command "focal_opt" instead.
For more detailed usage information for the command "focal_opt", you can please refer to its man page.
Hope this can help clarify the issue.
看来只能用focal_opt了
GMT+8, 2025-12-31 08:51 , Processed in 0.015245 second(s), 5 queries , Gzip On, Redis On.
