查看: 3087|回复: 2
[原创] VHDL
发表于 2013-3-11 21:47:14 | 显示全部楼层 |阅读模式
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
PACKAGE shift_type IS
SUBTYPE std4 IS STD_LOGIC_VECTOR(3 DOWNTO 0);
END shift_type;
LIBRARY IEEE;
USE WORK.shift_type.ALL;
ENTITY reg2 IS
PORT(din:IN std4;
     clk,load,left_right:IN STD_LOGIC;
     dout: BUFFER std4);
END reg2;
ARCHITECTURE rtl OF reg2 IS
SIGNAL shift_val: std4;
BEGIN
NXTROCESS(load,din,left_right,dout)
      BEGIN
      IF(load='1') THEN
      shift_val<=din;
      ELSIF(left_right='0') THEN
      shift_val(2 DOWNTO 0)<=dout(3 DOWNTO 1);
      shift_val(3)<='0';
      --ELSIF(left_right='1') THEN
      ELSE
      shift_val(3 DOWNTO 1)<=dout(2 DOWNTO 0);
      shift_val(0)<='0';
      END IF;
    END PROCESS;
CURRENTROCESS(clk)
          BEGIN
          IF(clk'EVENT AND clk='1') THEN
          dout<=shift_val;
          END IF;
        END PROCESS;
END rtl;
显示错误为:Error (10482): VHDL error at reg2.vhd(13): object "STD_LOGIC" is used but not declared
求各位大神帮忙
发表于 2013-3-12 00:47:24 | 显示全部楼层
此帖仅作者可见
 楼主| 发表于 2013-3-12 08:19:00 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-12-21 10:12 , Processed in 0.015500 second(s), 3 queries , Gzip On, Redis On.
