查看: 5165|回复: 1
[求助] Cadense安装问题
发表于 2013-3-11 10:34:53 | 显示全部楼层 |阅读模式
Cadense SPB16.5首次安装中途取消,重新安装第二步Product Installation时弹出Candence SPB/OrCAD 16.5-InstallShield Wizard对话框,内容如下;
SPB/OrCAD 16.5 is already installed on this system in current user(Only for me)mode by'Htx-28'.To use the existing installed products,run the configuration utility from start menu under Cadence>Release 16.5>Configure.This utility will give you access to the installed products without changing the existing installation.
该怎么处理?
发表于 2013-3-12 08:48:50 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-10-6 06:36 , Processed in 0.015152 second(s), 6 queries , Gzip On, Redis On.
