查看: 4027|回复: 0
请教:ads1.0.1编译器ucos官方移植代码出错
发表于 2007-1-4 06:52:42 | 显示全部楼层 |阅读模式
用ads1.0.1的编译器跑ucosII的移植代码,出现如下错误
"Micrium/Ports/arm/os_cpu_a.s", line 28 (column 12): Error: A1163E: Unknown opcode
   28 00000000             PUBLIC  OS_CPU_SR_Save               ; Functions declared in this file
"Micrium/Ports/arm/os_cpu_a.s", line 82: Fatal error: A1355U: A Label was found which was in no AREA 82 00000000 OS_CPU_SR_Save
用的是从ucos官方网站下载的arm的移植代码1.50版,这个os_cpu_a.s文件我没改动过,出错的源代码如下
28:    PUBLIC  OS_CPU_SR_Save
        RSEG CODE:CODE:NOROOT(2)
        CODE32
82:OS_CPU_SR_Save
        MRS     R0,CPSR
请高手指教,这个编译错误怎么解决?谢谢
GMT+8, 2025-12-30 09:59 , Processed in 0.535183 second(s), 6 queries , Gzip On, Redis On.
