查看: 22836|回复: 42
HFSS 15.02出来了,期待和谐版本
发表于 2013-3-9 14:16:08 | 显示全部楼层 |阅读模式
120x180 广告位
虚位以待
非礼勿视
了解详情
HFSS 15.0.2 Service Pack Updates
DE49482: Corrects an error in field computation of fast sweep solutions
DE51733: The correct number of HPC licenses are now checked out when multi-processing is
         utilized in an HFSS-IE distributed memory simulation.
DE50650: Matrix convergence definitions will be saved properly when the solution setup is
         established by script.
DE46980: Addresses a domain solver hang in designs that incorporate many metallic sheet
         IE regions
DE47597: Corrects the far-field calculation when an infinite ground plane is present in a
         design that contains a dielectric IE region
DE48956: Fixes erroneous S-parameters that result from including an anisotropic impedance
         boundary in a design
DE52269: Corrects a far-field calculation error that occurs in some cases when an infinite
DE51510: Fixes a mesh read failure that can occur during simulations that use MPI
DE49098: A proper error message is now displayed when computer RAM is depleted during a
         domain simulation.
DE47882: Removes an unnecessary validation check in the solver for master/slave faces
         in finite array designs
DE50376: Corrects an erroneous far-field result that can arise when an IE radiation
         boundary touches a metal surface
DE49069: Fixes an HFSS desktop crash that occurs for some DXF geometry imports
DE49246: Correctly handles edge directions in exporting non-linear geometry in GDSII export
DE49657: Exports elliptical arcs as segments instead of circular arcs to avoid distortion
DE44968: MATLAB optimizations will now operate as expected.
DE48872: Eliminates a hang in the scheduler integration panel for large LSF and SGE
         computing clusters
DE49976: Corrects a defect in the ramp color map of 3D plots and field overlay plots that
         blackens the plot for certain colors
DE51916: The "Limit number of engines per node to" setting in the job scheduler panel
         will now be respected.
DE49692: The proper number of primary sweep points will now appear in data exports of
         multi-curve plots.
US64313: Improvements to Large-Scale DSO
         - Corrects a data error during result extraction for certain design variations
         - Uniform time sampling can now be specified with just the name of the primary sweep
         - Traces that are not tied to the state of design will now be ignored
发表于 2013-3-9 16:18:01 | 显示全部楼层
hfss15都没破解,还hfss15.02啊。嘿嘿
发表于 2013-3-9 16:40:22 | 显示全部楼层
没破解呀!
发表于 2013-3-9 19:04:32 | 显示全部楼层
同时期待啊
发表于 2013-3-9 22:12:39 | 显示全部楼层
看起来15的错误还蛮多的,其计算结果是否可靠啊。
另外为什么Ansoft的官网上最新HFSS还是14, 而ADK工具包和HFSS全书还停留在V12?
发表于 2013-3-11 17:03:40 | 显示全部楼层
期待破解,可是15的都不知道怎么样呢?
发表于 2013-3-12 02:02:20 | 显示全部楼层
等破解了...........
发表于 2013-3-12 07:13:13 | 显示全部楼层
灌水灌水
发表于 2013-3-12 07:19:24 | 显示全部楼层
超好用的Source Insight 3 VHDL语言模板
发表于 2013-3-12 07:32:20 | 显示全部楼层
灌水灌水
GMT+8, 2025-9-19 21:08 , Processed in 1.450627 second(s), 6 queries , Gzip On, Redis On.
