查看: 25458|回复: 89
[原创] Integrated Circuits for Analog Signal Processing (Springer 2013)
发表于 2013-3-1 10:34:07 | 显示全部楼层 |阅读模式
This book presents theory, design methods and novel applications for integrated circuits for analog signal processing. The discussion covers a wide variety of active devices, active elements and amplifiers, working in voltage mode, current mode and mixed mode. This includes voltage operational amplifiers, current operational amplifiers, operational transconductance amplifiers, operational transresistance amplifiers, current conveyors, current differencing transconductance amplifiers, etc. Design methods and challenges posed by nanometer technology are discussed and applications described, including signal amplification, filtering, data acquisition systems such as neural recording, sensor conditioning such as biomedical implants, actuator conditioning, noise generators, oscillators, mixers, etc. Presents analysis and synthesis methods to generate all circuit topologies from which the designer can select the best one for the desired application; Includes design guidelines for active devices/elements with low voltage and low power constraints;Offers guidelines for selecting the right active devices/elements in the design of linear and nonlinear circuits;Discusses optimization of the active devices/elements for process and manufacturing issues of nanometer technology.
Integrated Circuit for Analog Signal Processing.pdf (11.24 MB , 下载次数: 2391 )
发表于 2013-3-1 18:33:47 | 显示全部楼层
大师兄,我来顶你……
发表于 2013-3-1 21:55:35 | 显示全部楼层
very good!!
发表于 2013-3-3 17:58:58 | 显示全部楼层
Design Of_Multiplayer_Spiral_Inductor_Resonator_Filter_And_Diplexer_For SiP
发表于 2013-3-4 13:10:53 | 显示全部楼层
keep for reference
发表于 2013-3-4 14:37:18 | 显示全部楼层
感谢分享,非常好的书
发表于 2013-3-4 23:59:23 | 显示全部楼层
学习下
发表于 2013-3-5 02:29:17 | 显示全部楼层
非常感谢
发表于 2013-3-5 03:17:57 | 显示全部楼层
Clapping! Thanks for sharing the book.
发表于 2013-3-5 07:45:14 | 显示全部楼层
nice! more?
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 07:26 , Processed in 0.019761 second(s), 5 queries , Gzip On, Redis On.
