查看: 3365|回复: 2
支持android的Verilog设计仿真工具!
发表于 2013-1-30 13:35:12 | 显示全部楼层 |阅读模式
硬件设计师要花费99%的时间在设计与仿真上,只有1%的时间在综合,布局布线和下载到芯片的过程。为什么不对自己好一点,选用一款看着舒适用着舒服的工具?
若贝软件是一款全新的芯片设计仿真工具。该软件是先进的图形化与代码设计相融合的设计工具,同时具备Verilog编译仿真和波形分析,可以实现各种系统的设计,仿真和测试。软件生成标准的Verilog代码,可以直接与各种EDA工具相融合。界面美观,简洁,15分钟就可以熟悉软件的操作,对比其他大型复杂软件,可以节省很多时间来实现同样的功能。
andriod,请访问:https://play.google.com/store/apps/details?id=org.kde.necessitas.example.Robei2
 楼主| 发表于 2013-1-30 13:36:28 | 显示全部楼层
Robei is the world smallest EDA tool for FPGA design and simulation. With this tool, you can design your hardware visually at anywhere, and view the simulation result through waveform. It is a tiny, fast software for hardware prototyping and verification.
Imagine that when you are waiting for a bus, on a business travel or lying on the bed, suddenly a genius idea for a piece of hardware showing to your mind, how can you implement it with just mobile phones or tablets? Robei runs on any Android platform, you can implement your design and test it immediately in such situation.
发表于 2013-1-30 15:04:49 | 显示全部楼层
interesting tool !!!
GMT+8, 2025-12-18 19:57 , Processed in 0.021892 second(s), 6 queries , Gzip On, Redis On.
