查看: 6261|回复: 12
CentOS6.3 安装sentaurus 2010启动问题求解
发表于 2013-1-29 14:15:13 | 显示全部楼层 |阅读模式
按照论坛里各类教程和材料,经过多番纠结将sentaurus各种问题都解决了大半,但是还有一个问题无论怎么尝试,不断google国内外论坛都没能解决:
[root@dusk dusk]# GENESISe
***                         Sentaurus Workbench                          ***
***                          Version D-2010.03                           ***
***                        (1.6, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2010                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
SWB warning: Calibration Kit library does not exist
genesis error: couldn't find the global tool database '../glib/tooldb.tcl'
错误提示所指的glib已经安装过glib-1.2.10-33.el6.rf.i686,glib-devel-1.2.10-33.el6.rf.i686,glib2-2.22.5-7.el6.i686,glib2-devel-2.22.5-7.el6.i686,glibc-2.12-1.80.el6_3.6.i686,glibc-devel-2.12-1.80.el6_3.6.i686。但是依旧是以上提示。我一直纠结是不是centos6.3的版本太高了所以装不上。
发表于 2013-1-29 15:16:45 | 显示全部楼层
not compatible
use Centos 5.8
 楼主| 发表于 2013-2-24 15:37:24 | 显示全部楼层
回复 2# azaki3k
    it shows the same message in fedora 12
发表于 2013-2-27 18:29:29 | 显示全部楼层
use only Centos 5.8
not centos 6 or any other version
 楼主| 发表于 2013-3-2 20:25:07 | 显示全部楼层
回复 4# azaki3k
i try it in centos 5.8 and still the same problem
发表于 2014-3-24 12:29:21 | 显示全部楼层
楼主后来怎么解决的,我现在也遇到一样的问题..
发表于 2014-3-26 22:07:28 | 显示全部楼层
搞定了,我的是bashrc里面路径写得不对
发表于 2014-3-26 22:33:34 | 显示全部楼层
非常感谢
发表于 2014-3-29 18:09:40 | 显示全部楼层
非常感谢提醒
发表于 2015-4-28 14:40:59 | 显示全部楼层
回复 8# v7cent
我现在也遇到同样的问题,麻烦您帮忙回忆一下当时bashrc是怎么设置的,非常感谢!
GMT+8, 2025-12-22 21:19 , Processed in 0.022007 second(s), 4 queries , Gzip On, Redis On.
