查看: 9215|回复: 34
[资料] The Design and Implementation of Low Voltage CMOS ΔΣ Modulators
发表于 2013-1-26 23:50:16 | 显示全部楼层 |阅读模式
The Design and Implementation of Low Voltage CMOS Delta Sigma Modulators
指导教授:刘深渊博士
研 究 生:郭 建 宏
Abstract
With rapid growth of the marketing in the portable electronic products, there is
a strong demand for developing low voltage and low power circuit technique to
increase the system level integration density and prolong the battery lifetime.
Fortunately, the continued scaling on the VLSI technology leads to the reduction of
the supply voltage, and it is also beneficial for the scaling of the battery size and
weight. The reduced supply voltage results in the power saving in digital circuits, but
complicates the design of high resolution analog circuits. In addition, the resulted
power dissipation in analog circuit is not proportional to the lowered supply voltage
as expected. It is a great challenge to maintain the desired performance of the AD
converter while the supply voltage is reduced.
Delta sigma (ΔΣ) modulators are insensitive to the imperfections on the analog
components such as the device mismatch and amplifier gain, which are especially
important for the low voltage applications. This scheme is well suitable for the
realization of a high resolution, accuracy and narrow band analog-to-digital (AD)
converter in audio and telecommunications applications. They also have the
advantage of relaxing the requirements of the analog anti-aliasing filters in the AD
converters. On the other hand, there is no significant power consumption and noise
penalty for the AD conversion of the ΔΣ modulator in IF band.
In this thesis, three low voltage ΔΣ modulators were explored and fabricated in
the standard 0.25μm CMOS 1P5M process for the audio and FM receiver applications.
First, a 1V nested-chopper second-order ΔΣ modulator is proposed to reduce both the
flicker noise (1/f noise) and residual noise. The input dynamic range of the modulator
is 69 dB with a bandwidth of 22.05kHz and a sampling rate of 2.5MHz. Second, a 1V
second-order ΔΣ modulator using a single opamp is presented to reduce the area
occupied and save the power dissipated. The maximum SNDR of the modulator is 68
dB with a audio bandwidth of 22.05kHz and a OSR of 64. Third, a 1V fourth-order
bandpass ΔΣ modulator with double-sampling technique is proposed to reduce the
sampling rate and the power consumption for the low voltage FM receiver
applications. The maximum SNDR of the modulators is 60 dB within a bandwidth of
200kHz. The sampling rate of the modulator is 7.13MHz with a power consumption
of 8.45mW.
III
TABLE OF CONTENTS
CHAPTER 1 INTRODUCTION......................................................................................... 1
1.1 MOTIVATION..................................................................................................................... 1
1.2 ORGANIZATION................................................................................................................ 2
CHAPTER 2 FUNDAMENTALS OF ΔΣ MODULATORS ............................................. 5
2.1 INTRODUCTION ................................................................................................................... 5
2.2 QUANTIZATION................................................................................................................... 6
2.2.1 QUANTIZATION ERROR ..................................................................................................... 7
2.2.2 PERFORMANCE METRICS ................................................................................................ 10
2.2.2.1 Resolution.................................................................................................................... 10
2.2.2.2 Signal-to-Noise Ratio (SNR)....................................................................................... 11
2.2.2.3 Signal-to-Noise plus Distortion Ratio (SNDR) ........................................................... 11
2.2.2.4 Dynamic Range ........................................................................................................... 11
2.2.3 SINGLE-BIT QUANTIZATION ............................................................................................ 12
2.2.4MULTI-BIT QUANTIZATION.............................................................................................. 13
2.3 OVERSAMPLING TECHNIQUE ........................................................................................... 14
2.3.1 NYQUIST-RATE A/D CONVERTERS................................................................................... 15
2.3.2ADVANTAGE OF OVERSAMPLING TECHNIQUE ................................................................ 15
2.3.3 QUANTIZATION NOISE MODEL........................................................................................ 17
2.4 NOISE-SHAPED ΔΣ MODULATOR .................................................................................... 17
2.4.1 FIRST-ORDER NOISE-SHAPING........................................................................................ 19
2.4.2 SECOND-ORDER NOISE-SHAPING ................................................................................... 22
2.4.3 HIGHER-ORDER NOISE-SHAPING.................................................................................... 24
2.4.3.1 Single-Loop Topology ................................................................................................. 25
2.4.3.2 Cascade Topology........................................................................................................ 26
2.5 MULTIBIT QUANTIZATION ΔΣ MODULATOR..................................................................... 27
2.6 BANDPASS ΔΣ MODULATOR............................................................................................ 28
2.7 SUMMARY ......................................................................................................................... 28
CHAPTER 3 THE DESIGN OF LOW VOLTAGE SWITCHED-CAPACITOR
CIRCUITS FOR ΔΣ MODULATORS................................................................................. 29
IV
3.1 INTRODUCTION ..................................................................................................................29
3.2 SWITCHED-CAPACITOR CIRCUITS....................................................................................30
3.3 LOW VOLTAGE SWITCHED-CAPACITOR CIRCUITS ..........................................................31
3.3.1 VOLTAGE BOOSTING TECHNIQUE ....................................................................................33
3.3.2MULTI-THRESHOLD VOLTAGE PROCESS ..........................................................................34
3.3.3 BOOTSTRAPPED SWITCH..................................................................................................35
3.3.3 BOOTSTRAPPED SWITCH AS A SAMPLING SWITCH ..........................................................36
3.4 THE ORIGINAL SWITCHED OPAMP PRINCIPLE ................................................................38
3.5 FULLY DIFFERENTIAL SWITCHED OPAMP WITH DOUBLED OUTPUT ..............................42
3.5.1 FULLY DIFFERENTIAL SWITCHED OPAMP ........................................................................42
3.5.2 COMMON MODE FEEDBACK (CMFB) .............................................................................44
3.5.4 SIMULATION RESULTS......................................................................................................46
3.6 LOW VOLTAGE QUANTIZER ..............................................................................................49
3.6.1 LOW VOLTAGE COMPARATOR..........................................................................................49
3.6.2 LOW VOLTAGE QUANTIZER .............................................................................................50
3.7 SUMMARY ..........................................................................................................................51
CHAPTER 4 THE LOW VOLTAGE NESTED-CHOPPER ΔΣ MODULATOR.........53
4.1 INTRODUCTION ..................................................................................................................53
4.2 NOISE CONSIDERATION ....................................................................................................53
4.2.1AUTOZEROING AND CORRELATED DOUBLE SAMPLING (CDS)........................................54
4.2.2 CHOPPER STABILIZED SCHEME........................................................................................55
4.2.3 RESIDUAL NOISE AND NESTED-CHOPPER AMPLIFIER .....................................................56
4.3 CHOPPER-STABILIZED ΔΣ MODULATOR..........................................................................58
4.4 NESTED-CHOPPER ΔΣ MODULATOR................................................................................60
4.4.1 CONSIDERATION ..............................................................................................................60
4.4.2 NESTED-CHOPPER IN ΔΣMODULATOR............................................................................61
4.5 SYSTEM CONSIDERATION.................................................................................................63
4.5.1 A Second-Order ΔΣ Modulator .......................................................................................63
4.5.2 A Highpass Second-Order ΔΣ Modulator........................................................................64
4.5.3 The First Stage.................................................................................................................65
4.5.4 The Second Stage ............................................................................................................67
4.5.5 Comparator.....................................................................................................................70
4.6 NOISE ANALYSIS ...............................................................................................................70
4.6.1 The First Stage.................................................................................................................70
4.6.2 Jitter Noise.......................................................................................................................75
4.7 SIMULATION......................................................................................................................75
V
4.7.1 The Finite Gain of the Opamp ........................................................................................ 76
4.7.2 MATLAB Simulation ..................................................................................................... 77
4.7.3 HSPICE Simulation........................................................................................................ 79
4.8 EXPERIMENTAL RESULTS ................................................................................................ 80
4.8.1 Input Signal Source and Input Termination Circuit........................................................ 81
4.8.2 Power Supply and Ground.............................................................................................. 81
4.8.3 Reference Voltage Generator .......................................................................................... 82
4.8.4 Layout and Pin Assignment ............................................................................................ 84
4.8.5 Measurement Results...................................................................................................... 85
4.9 SUMMARY ......................................................................................................................... 89
CHAPTER 5 A LOW-VOLTAGE SECOND-ORDER ΔΣ MODULATOR USING
SINGLE OPAMP................................................................................................................... 91
5.1 INTRODUCTION ................................................................................................................. 91
5.2 SYSTEM CONSIDERATIONS.............................................................................................. 91
5.3 IMPLEMENTATION.............................................................................................................. 94
5.3.1 INTEGRATOR.................................................................................................................... 94
5.3.2 QUANTIZER ..................................................................................................................... 98
5.3.3MULTIPLEXER ................................................................................................................. 98
5.3.4 DAC FEEDBACK ............................................................................................................. 99
5.3.5ASECOND-ORDER INTEGRATOR WITH DAC FEEDBACK .............................................. 100
5.4 CLOCK GENERATOR....................................................................................................... 100
5.5 SIMULATION RESULTS.................................................................................................... 101
5.6 EXPERIMENTAL RESULTS .............................................................................................. 104
5.7 SUMMARY ....................................................................................................................... 107
CHAPTER 6 A LOW-VOLTAGE FOURTH-ORDER BANDPASS ΔΣ MODULATOR
.............................................................................................................................................. 109
6.1 INTRODUCTION ............................................................................................................... 109
6.2 SYSTEM CONSIDERATION ...............................................................................................111
6.2.1 The Sampling Frequency.............................................................................................. 113
6.3 IMPLEMENTATION.............................................................................................................114
6.3.1 The First Resonator....................................................................................................... 115
6.3.2 The Second Resonator .................................................................................................. 119
6.3.3 Quantizers..................................................................................................................... 122
6.3.4 The Multiplexers........................................................................................................... 123
VI
6.4 SIMULATION.....................................................................................................................123
6.5 EXPERIMENTAL RESULTS ...............................................................................................126
6.5.1 Input Termination Circuit ..............................................................................................127
6.5.2 Layout and Pin Assignment...........................................................................................127
6.5.3 Measurement Results ....................................................................................................128
6.6 SUMMARY ........................................................................................................................131
CHAPTER 7 CONCLUSIONS........................................................................................133
7.1 CONCLUSIONS.................................................................................................................133
7.2 RECOMMENDATIONS FOR FUTURE WORKS...................................................................134
APPENDIX ...........................................................................................................................135
A.1 INTRODUCTION................................................................................................................135
A.2 CONSIDERATIONS OF THE DESIGN ................................................................................136
A. NONLINEAR ERROR OF THE DAC.......................................................................................136
B. FOUR POINTER DWA(FPDWA).........................................................................................136
A.3 BEHAVIORAL SIMULATION..............................................................................................139
A.4 CIRCUIT IMPLEMENTATION.............................................................................................140
A. SECOND-ORDER DELTA-SIGMA MODULATOR WITH NINE-LEVEL QUANTIZATION ...............140
B. DIGITAL-ANALOG CONVERTER (DAC)..............................................................................146
A.5 CONCLUSIONS ................................................................................................................149
PUBPLICATION LIST .......................................................................................................151
BIBLIOGRAPHY ................................................................................................................153
List of Tables
VII
List of Tables
Table 1.1 Important parameters of some audio technologies...…................... 2
Table 3.1 Performance summary of simulation results of the switch-opamp. 49
Table 4.1 Performance comparison with some other publications………….. 89
Table 5.1 Performance summary of the low voltage second-order ΔΣ
modulator..………………………………………………………... 108
Table 6.1 The performance comparison with other literatures published…... 131
Appendix
Table A.1 The peak SNDR and the peak outputs of the two integrators in
the modulator for different values of b …………………………... 141
Table A.2 Simulation performance of the Op Amp…………………………. 142
Table A.3 The capacitor sizes of the two integrators………………………... 144
Table A.4 The corresponding table of thermometer code and active code….. 146
Table A.5 The performance of the ΔΣ modulator………………….. 149
郭建宏博士论文.rar
1.86 MB, 下载次数: 367 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2013-1-27 00:23:48 | 显示全部楼层
Ding me
发表于 2013-1-27 10:16:34 | 显示全部楼层
发表于 2013-1-28 09:27:38 | 显示全部楼层
感謝大大的分享
发表于 2013-1-28 22:45:24 | 显示全部楼层
份額.............
发表于 2013-2-1 06:42:16 | 显示全部楼层
谢谢分享!
发表于 2013-2-2 10:44:46 | 显示全部楼层
回复 1# hi_china59
多谢!
发表于 2013-2-4 00:14:21 | 显示全部楼层
下来看看,博士论文,基本原理一般讲的多
发表于 2014-12-17 09:21:06 | 显示全部楼层
谢谢分享
发表于 2015-4-23 09:39:09 | 显示全部楼层
Low Voltage Audio Power Amplifier
GMT+8, 2025-12-26 14:36 , Processed in 0.026546 second(s), 7 queries , Gzip On, Redis On.
