查看: 6179|回复: 7
syn的license问题
发表于 2013-1-10 14:14:08 | 显示全部楼层 |阅读模式
各位论坛达人,请帮小弟我分析一下,不甚感激!
我在论坛上下的src,
scl也是用了论坛上的10.9.3和10.9.1,装了以后,起了DC和astro,都不行!以下是syn_lic.log;小弟我之前没有接触过,所以现在焦头烂额。我想知道到底是我安装scl的问题呢?还是license没有破解好?还是src不支持我的软件?
14:00:54 (lmgrd) -----------------------------------------------
14:00:54 (lmgrd)   Please Note:
14:00:54 (lmgrd)
14:00:54 (lmgrd)   This log is intended for debug purposes only.
14:00:54 (lmgrd)   In order to capture accurate license
14:00:54 (lmgrd)   usage data into an organized repository,
14:00:54 (lmgrd)   please enable report logging. Use Macrovision's
14:00:54 (lmgrd)   software license administration  solution,
14:00:54 (lmgrd)   FLEXnet Manager, to  readily gain visibility
14:00:54 (lmgrd)   into license usage data and to create
14:00:54 (lmgrd)   insightful reports on critical information like
14:00:54 (lmgrd)   license availability and usage. FLEXnet Manager
14:00:54 (lmgrd)   can be fully automated to run these reports on
14:00:54 (lmgrd)   schedule and can be used to track license
14:00:54 (lmgrd)   servers and usage across a heterogeneous
14:00:54 (lmgrd)   network of servers including Windows NT, Linux
14:00:54 (lmgrd)   and UNIX. Contact Macrovision at
14:00:54 (lmgrd)   www.macrovision.com for more details on how to
14:00:54 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
14:00:54 (lmgrd)   for your enterprise.
14:00:54 (lmgrd)
14:00:54 (lmgrd)
14:00:54 (lmgrd)
14:00:54 (lmgrd) FLEXnet Licensing (v10.8.3.1 build 30305) started on localhost (linux) (1/10/2013)
14:00:54 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
14:00:54 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:00:54 (lmgrd) World Wide Web:  http://www.macrovision.com
14:00:54 (lmgrd) License file(s): /EDA/license/SYN_license.dat
14:00:54 (lmgrd) lmgrd tcp-port 27000
14:00:54 (lmgrd) Starting vendor daemons ...
14:00:54 (lmgrd) Started snpslmd (internet tcp_port 50012 pid 22431)
14:00:54 (snpslmd) FLEXnet Licensing version v10.8.3.1 build 30305
14:00:57 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_10.9.1d
14:00:58 (snpslmd) Server started on localhost for:
SSS
14:00:58 (snpslmd) railmill
railmill/ace
railmill/av
14:00:58 (snpslmd) railmill/spnx
rslv3d
rslv3dviewer
14:00:58 (snpslmd) simwave
simwave_epic
spice_parser
14:00:58 (snpslmd) techviewer
timemill
timemill/ace
14:00:58 (snpslmd) timemill/av
timemill/bdc
timemill/msx
14:00:58 (snpslmd) vera_comp
vera_debug
vera_rtime
14:00:58 (snpslmd) vhdl_compiler
vlog2e
vtran
14:00:58 (snpslmd) ispLSI1K
ispLSI2K
ispLSI2KE
14:00:58 (snpslmd) ispLSI3K
ispLSI5000S
ispLSI5000SE
14:00:58 (snpslmd) ispLSI5K
ispLSI6K
ispLSI8K
14:00:58 (snpslmd) ispMACH4000
lsim_parser
pathmill
14:00:58 (snpslmd) pathmill/dsx
pathmill/pfx
pathmill/sfx
14:00:58 (snpslmd) pmga
powerarc
powrmill
14:00:58 (snpslmd) powrmill/ace
powrmill/av
powrmill/msx
14:00:58 (snpslmd) primepower
primepower_gui
provhdl_checker
14:00:58 (snpslmd) pwga
acega
amga
14:00:58 (snpslmd) amps
arc
arc/bcx
14:00:58 (snpslmd) arc/lefdef
arcviewer
arcviewer/raph
14:00:58 (snpslmd) arcxl
c_exe_ax
c_exe_cbx
14:00:58 (snpslmd) c_exe_gx
cadence
chipviewer
14:00:58 (snpslmd) cmod
cmod/ax
cmod/cbx
14:00:58 (snpslmd) cmod/gx
cmod/gxadv
coreConsultant
14:00:58 (snpslmd) eX
edif2e
gentech
14:00:58 (snpslmd) Verilog-To-BE
Vivace-Code-Generator Vivace-Core
14:00:58 (snpslmd) Vivace-Debug
Vivace-Elaborator Vivace-Expert
14:00:58 (snpslmd) Vivace-Express
Vivace-GUI
Vivace-HDL-Analyzer
14:00:58 (snpslmd) Vivace-Model-Compiler Vivace-Pro
Vivace-Simulator
14:00:58 (snpslmd) Vivace-VHDL-Analyzer WRITE
XC3000
14:00:58 (snpslmd) XC4000
XC4000E
XC4000EX
14:00:58 (snpslmd) XC4000L
XC4000XL
XC4000XLA
14:00:58 (snpslmd) XC4000XV
XC5200
XC9500
14:00:58 (snpslmd) XC9500XL
XC9500XV
XVCSDebugger
14:00:58 (snpslmd) VPC
VSP_DRIVER
VSS-Analyzer
14:00:58 (snpslmd) VSS-Backplane
VSS-CLI
VSS-Cadence-Interface
14:00:58 (snpslmd) VSS-CompiledSim VSS-Debugger
VSS-Falcon-Interface
14:00:58 (snpslmd) VSS-GateSim
VSS-LAI-Models
VSS-LMSI
14:00:58 (snpslmd) VSS-Lib-Tools
VSS-Model-Developer VSS-NEC-Tran
14:00:58 (snpslmd) VSS-SDF-Interface VSS-SGE-Tool
VSS-SPC
14:00:58 (snpslmd) VSS-Simulator
VSS-SmartModels VSS-Tran
14:00:58 (snpslmd) VSS-Utilities
VSS-VIP-Interface VSS-Verilog-PLI
14:00:58 (snpslmd) VSS-Wave-Display VSS-XP-Accelerator Verification-Token
Verilog-Netlist-Writer Verilog-Parser
14:00:58 (snpslmd) TestManager
TestSim
Ultra37000
14:00:58 (snpslmd) VANTIS
VCSCompiler_Net VCSDebugger_Net
14:00:58 (snpslmd) VCSPostProcDebugger_Net VCSRuntime_Net
VCSTools_Net
14:00:58 (snpslmd) VDesktop-Debug
VDesktop-GUI
VDesktop-VCDTrans
14:00:58 (snpslmd) VDesktop-VHDL
VDesktop-Verilog VHDL-Analyzer
14:00:58 (snpslmd) VHDL-Compiler
VHDL-Cycle-Sim
VHDL-Elaborator
14:00:58 (snpslmd) VHDL-Event-Sim
VHDL-Netlist-Writer VHDL-To-BE
14:00:58 (snpslmd) VHDL-VirSim
VHMC-Eval
VHMC-GenUnlocked
14:00:58 (snpslmd) VHMC-Runtime
VIRTEX
VIRTEX2
14:00:58 (snpslmd) VIRTEX2P
VIRTEXE
VIRTEXEA
14:00:58 (snpslmd) Test-Beta-2
Test-CA
Test-Compile
14:00:58 (snpslmd) Test-Compile-Remodel Test-Compile-Share Test-Compiler
14:00:58 (snpslmd) Test-Compiler-Plus Test-Compiler-Remodel Test-Custom-Protocols
14:00:58 (snpslmd) Test-DFT-Top
Test-Delay
Test-Diagnosis
14:00:58 (snpslmd) Test-Eval
Test-Faultsim
Test-Faultsim-8L
14:00:58 (snpslmd) Test-Format
Test-IDDQ
Test-IEEE-Std-1149-1
14:00:58 (snpslmd) Test-Library
Test-Map
Test-Mbist
14:00:58 (snpslmd) Test-Mbist-Algorithm Test-Mbist-CAM
Test-Mbist-DRAM
14:00:58 (snpslmd) Test-Mbist-Diagnosis Test-Mbist-FLASH Test-Mbist-Multiport
14:00:58 (snpslmd) Test-RTL-Check
Test-ScanRoute
SynLib-Eval
14:00:58 (snpslmd) SynLib-FltTol
SynLib-PCIbasic SynLib-Seq
14:00:58 (snpslmd) SynLib-VHDLSimMdl SynLib-VerilogSimMdl Synopsys
14:00:58 (snpslmd) Synopsys-Queue
Synopsys-Release TBM-Manager-UI
14:00:58 (snpslmd) TBM-VSS-Check
TBS
TC-Beta
14:00:58 (snpslmd) TDL-Interface
TDL-Reader
TDL-Writer
14:00:58 (snpslmd) TRUE
Test-ATPG
Test-ATPG-30
14:00:58 (snpslmd) Test-ATPG-Limited Test-ATPG-PRO
Test-ATPG-Ultra
14:00:58 (snpslmd) Test-ATPG-XP
Test-Accelerator Test-Analysis
14:00:58 (snpslmd) Test-Analysis-GUI Test-Analysis-RTL Test-BIST
14:00:58 (snpslmd) Test-BSDL
Test-Beta
QLOGIC
14:00:58 (snpslmd) Quantum38k
RT54SXS
RTL-Analyzer
14:00:58 (snpslmd) RTL-Analyzer-DAP RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP
14:00:58 (snpslmd) RTL-Power-Analysis SGE-DC-Interface SGE-EDIF-Interface
14:00:58 (snpslmd) SGE-Tool
SGE-VHDL-Interface SGE-Verilog-Interface
14:00:58 (snpslmd) SNPS-CSL
SNPS-Keygen
SNPS-MOTIVE
14:00:58 (snpslmd) SPARTAN
SPARTAN2
SPARTAN2E
14:00:58 (snpslmd) SPARTANXL
SYNARIO
ShortCut-DC-Expert
14:00:58 (snpslmd) ShortCut-DC-Pro Shortcut-FPGA
Stamp-Compiler
14:00:58 (snpslmd) Syn-Library-Compiler SynLib-ALU
SynLib-AdvMath
14:00:58 (snpslmd) SynLib-Control
SynLib-DSPFIR
MIF-Reader
14:00:58 (snpslmd) MIF-Writer
MOTIVE-PrimeTime Mentor-Interface
14:00:58 (snpslmd) Millennium-ATPG-EE Millennium-ATPG-STD Millennium-Beta
14:00:58 (snpslmd) Millennium-DRC
Millennium-Eval Millennium-FS
14:00:58 (snpslmd) Mixed-Language
Mixed-Paradigm
ORCA2A
14:00:58 (snpslmd) ORCA2TB
ORCA3C
ORCA3FPSC
14:00:58 (snpslmd) ORCA3L
ORCA4E
Parse-Tree-Translator
14:00:58 (snpslmd) PhysOpt-GUI
Power-Analysis
Power-Optimization
14:00:58 (snpslmd) Power-Optimization-Upgrade PrimeTime
PrimeTime-Plus
14:00:58 (snpslmd) Protocol-Compiler-Analysis Protocol-Compiler-COutput Protocol-Compiler-FML
14:00:58 (snpslmd) Protocol-Compiler-Synth Protocol-Compiler-UI Library-Compiler
14:00:58 (snpslmd) MACH1
MACH2
MACH4
14:00:58 (snpslmd) MACH5
MAX3000A
MAX7000
14:00:58 (snpslmd) MAX7000A
MAX7000AE
MAX7000B
14:00:58 (snpslmd) MAX7000E
MAX7000S
MAX9000
14:00:58 (snpslmd) MC-Pro
MC-Pro-RP
MC-Retime
14:00:58 (snpslmd) MCD
MCE
MCE-Base
14:00:58 (snpslmd) MCE-Eval
MCE-Lib-ALU
MCE-Lib-Arith1
14:00:58 (snpslmd) MCE-Lib-Arith2
MCE-Lib-Arith3
MCE-Lib-Logic
14:00:58 (snpslmd) MEMPRO
MEMPRO-LIB
MERCURY
14:00:58 (snpslmd) FPGA_Express-APROA-Optimizer FSM-Reader
FSM-Writer
14:00:58 (snpslmd) Flash370i
Floorplan-Management Formality
14:00:58 (snpslmd) Formality-E1
Fridge-GUI
Fridge-Interpolator
14:00:58 (snpslmd) FusionVantageLmcInterface GENERICVSP
HDL
14:00:58 (snpslmd) HDL-Advisor
HDL-Advisor-Estimator HDL-Advisor-Estimator-Package
14:00:58 (snpslmd) HDL-Advisor-Package HDL-Advisor-Shell HDL-Advisor-Shell-Estimator
14:00:58 (snpslmd) HDL-Advisor-Shell-Estm-Package HDL-Advisor-Shell-Package HDL-Compiler
14:00:58 (snpslmd) HighLevel-Power-Analysis HighLevel-Power-Optimization Interface-Shell
14:00:58 (snpslmd) Key-Generator
LMCSwift_Net
LSI-Interface
14:00:58 (snpslmd) LSI-OEM
LSS4E
Leakage-Power
14:00:58 (snpslmd) FPGA-Express-EPM7k-Optimizer FPGA-Express-EPM9k-Optimizer FPGA-Express-GAT
14:00:58 (snpslmd) FPGA-Express-ISP4000-Optimizer FPGA-Express-ISP5000-Optimizer FPGA-Express-MERCURY-Optimizer
14:00:58 (snpslmd) FPGA-Express-ORCA2-Optimizer FPGA-Express-ORCA3-Optimizer FPGA-Express-Open-Optimizer
14:00:58 (snpslmd) FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base FPGA-Express-VHDL-Training
14:00:58 (snpslmd) FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base FPGA-Express-XC3k-Optimizer
14:00:58 (snpslmd) FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer FPGA-Express-XC9k-Optimizer
14:00:58 (snpslmd) FPGA-Express-isp1K-Optimizer FPGA-Express-isp2K-Optimizer FPGA-Express-isp3K-Optimizer
14:00:58 (snpslmd) FPGA-Express-isp4K-Optimizer FPGA-Express-isp5K-Optimizer FPGA-Express-isp6K-Optimizer
14:00:58 (snpslmd) FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer FPGA-HDL-Bundle
14:00:58 (snpslmd) FPGA-Library-Compiler FPGA-Option
FPGA-VHDL-Bundle
14:00:58 (snpslmd) Early-Access-Technology Equation-Reader Equation-Writer
14:00:58 (snpslmd) Espresso-Reader Espresso-Writer Estm-HDL-Advisor
14:00:58 (snpslmd) Estm-HDL-Advisor-Package Eview
FCII-Altera-Edition
14:00:58 (snpslmd) FLEX10K
FLEX10KA
FLEX10KB
14:00:58 (snpslmd) FLEX10KE
FLEX6000
FLEX8000
14:00:58 (snpslmd) FPGA-Compiler
FPGA-Express
FPGA-Express-32OODx-Optimizer
14:00:58 (snpslmd) FPGA-Express-A1200XL-Optimizer FPGA-Express-A1400-Optimizer FPGA-Express-A3200DX-Optimizer
14:00:58 (snpslmd) FPGA-Express-A42MX-Optimizer FPGA-Express-A54SX-Optimizer FPGA-Express-APEX2-Optimizer
14:00:58 (snpslmd) FPGA-Express-APROA-Optimizer FPGA-Express-Constraint-Mgr FPGA-Express-EP20k-Optimizer
14:00:58 (snpslmd) FPGA-Express-EPF10k-Optimizer FPGA-Express-EPF6k-Optimizer FPGA-Express-EPF8k-Optimizer
14:00:58 (snpslmd) DesignWare-8051MCU DesignWare-Cardbus DesignWare-Developer-MGI
14:00:58 (snpslmd) DesignWare-Ethernet DesignWare-Foundation DesignWare-Foundation-Exp
14:00:58 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
14:00:58 (snpslmd) DesignWare-ISA-PnP DesignWare-MGI
DesignWare-PCIbasic
14:00:58 (snpslmd) DesignWare-Package DesignWare-VERA Designware-Basic
14:00:58 (snpslmd) Designware-Developer Designware-FPGA-Basic E5
14:00:58 (snpslmd) E502
E505
E520
14:00:58 (snpslmd) ECL-Compiler
ECO-Compiler
EDIF-Netlist-Read-DC
14:00:58 (snpslmd) EDIF-Netlist-Write-DC EDIF-Netlist-Writer EDIF-Reader
14:00:58 (snpslmd) EDIF-Schematic-Writer EXCALIBUR_ARM
EXCALIBUR_MIPS
14:00:58 (snpslmd) DEMO
DIRECTMEM
DS-Schem-Gen
14:00:58 (snpslmd) DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package DS-Schem-Gen-Package
14:00:58 (snpslmd) DS-Verinet
DS-Verinet-Estimator-Pack DS-Verinet-Estimator-Package
14:00:58 (snpslmd) DS-Verinet-Package DS-Vhdlnet
DS-Vhdlnet-Estimator-Pack
14:00:58 (snpslmd) DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package DW-Developer
14:00:58 (snpslmd) DW-IP-Consultant DW-IP-Developer Delta39k
14:00:58 (snpslmd) Design-Analyzer Design-Analyzer-DAP Design-Budgeting
14:00:58 (snpslmd) Design-Compiler Design-Estimator Design-Estimator-FPI
14:00:58 (snpslmd) Design-Vision
DesignSource
DesignSource-Estimator-Package
14:00:58 (snpslmd) DesignSource-Package DesignTime
DesignWare
14:00:58 (snpslmd) COSSAP_vsiccg_vcs COSSAP_vsiccg_vlgxl COSSAP_vsivcg
14:00:58 (snpslmd) COSSAP_vsivcg_vlgxl COSSAP_xdcg
COSSAP_xvcg
14:00:58 (snpslmd) COSSAP_xvsi
CTV-Interface
CYPRESS
14:00:58 (snpslmd) CmView
CoverMeter
Cyclone-Code-Generator
14:00:58 (snpslmd) Cyclone-Core
Cyclone-Elaborator Cyclone-GUI
14:00:58 (snpslmd) Cyclone-HDL-Analyzer Cyclone-Simulator Cyclone-VHDL-Analyzer
14:00:58 (snpslmd) Cyclone-cosim
DATAIO
DC-Beta
14:00:58 (snpslmd) DC-Cadence-Interface DC-Expert
DC-Falcon-Interface
14:00:58 (snpslmd) DC-Layout-Interface DC-Min-Area-Retime DC-SDF-Interface
14:00:58 (snpslmd) DC-Ultra-Features DC-Ultra-Opt
DCM-Delay-Calculation
14:00:58 (snpslmd) COSSAP_dect
COSSAP_dvb
COSSAP_ecc
14:00:58 (snpslmd) COSSAP_gsmdve
COSSAP_gsmdve_utils COSSAP_gsmefrsc
14:00:58 (snpslmd) COSSAP_gsmeq
COSSAP_gsmfrcc
COSSAP_gsmfrsc
14:00:58 (snpslmd) COSSAP_gsmhrcc
COSSAP_gsmhrsc
COSSAP_gsmphy
14:00:58 (snpslmd) COSSAP_is136
COSSAP_is95
COSSAP_matlab
14:00:58 (snpslmd) COSSAP_mfd
COSSAP_mpeg2
COSSAP_pdc
14:00:58 (snpslmd) COSSAP_qed
COSSAP_sds
COSSAP_srcfd
14:00:58 (snpslmd) COSSAP_vcg_generic COSSAP_vcg_synopsys COSSAP_vcg_vantage
14:00:58 (snpslmd) COSSAP_vdefcg
COSSAP_vdefcg_vlgxl COSSAP_vsiccg
14:00:58 (snpslmd) COSSAP_vsiccg_cyc COSSAP_vsiccg_mti COSSAP_vsiccg_mtivlg
14:00:58 (snpslmd) COOLRUNNER
COOLRUNNER2
COSSAP_adpcm
14:00:58 (snpslmd) COSSAP_arm
COSSAP_bde
COSSAP_celp
14:00:58 (snpslmd) COSSAP_chart
COSSAP_cw_filter_hdl COSSAP_cw_filter_sds
14:00:58 (snpslmd) COSSAP_dab
COSSAP_dcg_ad21020 COSSAP_dcg_ansic
14:00:58 (snpslmd) COSSAP_dcg_ariel32c COSSAP_dcg_fe
COSSAP_dcg_gc
14:00:58 (snpslmd) COSSAP_dcg_krc
COSSAP_dcg_lsic30s COSSAP_dcg_m96000
14:00:58 (snpslmd) COSSAP_dcg_mp
COSSAP_ddk_arm
COSSAP_ddk_devlp
14:00:58 (snpslmd) COSSAP_ddk_dsp1610 COSSAP_ddk_hawk COSSAP_ddk_nec
14:00:58 (snpslmd) COSSAP_ddk_oak
COSSAP_ddk_pine COSSAP_ddk_ssp16xx
14:00:58 (snpslmd) COSSAP_ddk_tic5x COSSAP_ddk_tic5xx BC-FPGA-HDL
14:00:58 (snpslmd) BC-FPGA-VHDL
BC-HDL
BC-Schedule
14:00:58 (snpslmd) BC-VHDL
BOA-BRT
Behavioral-Analyzer
14:00:58 (snpslmd) Behavioral-Compiler CA-CP-Advanced
CA-CP-Basic
14:00:58 (snpslmd) CA-CP-Standard
CA-Chip-Edit
CA-Foundation
14:00:58 (snpslmd) CA-Frame
CA-Hier-Timer
CA-Optimization
14:00:58 (snpslmd) CA-Timer
CA-Utils
CD-Compiled-Lib-Gen
14:00:58 (snpslmd) CD-Compiled-Sys-Gen CD-GDI
CD-GDII-Link
14:00:58 (snpslmd) CD-MSSC-Cross-Probe CD-MSSC-Netlist CD-Model-Developer
14:00:58 (snpslmd) CD-Present-Builder CD-Present-Layer-Gen CD-REX
14:00:58 (snpslmd) CD-Vhdlgen-GUI
CD-Vhdlgen-Gen
A3200DX
14:00:58 (snpslmd) A42MX
A500K
A54SX
14:00:58 (snpslmd) A54SXA
A7
ACEX1K
14:00:58 (snpslmd) ACS
ACT2-1200XL
ACT3
14:00:58 (snpslmd) ALTGEN1
ALTGEN2
APEX20K
14:00:58 (snpslmd) APEX20KC
APEX20KE
APEXII
14:00:58 (snpslmd) ARKOS-A
ARKOS-B
ARKOS-C
14:00:58 (snpslmd) ARKOS-D
ARKOS-E
ARKOS-Ice
14:00:58 (snpslmd) ARKOS-Mcomp
ARKOS-Rtlcomp
ARKOS-Scomp
14:00:58 (snpslmd) ARKOS-Simul
ARM7TDMI
ATMEL
14:00:58 (snpslmd) ATMWB_ATMLAYER
ATMWB_UTOPIA
14:00:58 (snpslmd)
14:00:58 (snpslmd) Licenses are case sensitive for TE_CATS
14:00:58 (snpslmd)
14:00:58 (lmgrd) snpslmd using TCP-port 50012
14:00:58 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
14:00:58 (snpslmd) ------------------------------------------------------------------
14:00:58 (snpslmd) Checking the integrity of the license file....
14:00:58 (snpslmd) Valid SSS feature found.
14:00:58 (snpslmd) The feature is needed to enable the other keys in your license file.
14:01:51 (snpslmd) TCP_NODELAY NOT enabled
14:04:36 (snpslmd) UNSUPPORTED: "Astro" (PORT_AT_HOST_PLUS   ) yym@localhost  (License server system does not support this feature. (-18,327))
14:04:36 (snpslmd) UNSUPPORTED: "Milkyway" (PORT_AT_HOST_PLUS   ) yym@localhost  (License server system does not support this feature. (-18,327))
14:04:36 (snpslmd) UNSUPPORTED: "MDataPrep" (PORT_AT_HOST_PLUS   ) yym@localhost  (License server system does not support this feature. (-18,327))
14:04:36 (snpslmd) UNSUPPORTED: "Apollo" (PORT_AT_HOST_PLUS   ) yym@localhost  (License server system does not support this feature. (-18,327))
14:04:36 (snpslmd) UNSUPPORTED: "SolarII" (PORT_AT_HOST_PLUS   ) yym@localhost  (License server system does not support this feature. (-18,327))
14:04:36 (snpslmd) UNSUPPORTED: "aPrv" (PORT_AT_HOST_PLUS   ) yym@localhost  (License server system does not support this feature. (-18,327))
 楼主| 发表于 2013-1-10 14:21:56 | 显示全部楼层
顶一个
 楼主| 发表于 2013-1-11 08:48:42 | 显示全部楼层
哦,没有人回答,只好自己回答了
问题搞定,还是下载的src文件不行,换了一个就没有问题的,呵呵
发表于 2013-4-18 11:44:20 | 显示全部楼层
最后用的哪一版的src share 一下把
发表于 2013-4-18 12:17:57 | 显示全部楼层
路过,看看
发表于 2014-11-30 22:24:33 | 显示全部楼层
发表于 2015-6-9 10:09:53 | 显示全部楼层
楼主解决了吗~
发表于 2017-2-6 19:27:28 | 显示全部楼层
看看先
GMT+8, 2025-10-14 23:42 , Processed in 0.020500 second(s), 4 queries , Gzip On, Redis On.
