查看: 2302|回复: 2
Cadence IC610 installation Problem
发表于 2015-10-11 16:02:02 | 显示全部楼层 |阅读模式
I have tried to install the ic610 on Red Hat Linux (v4.6, 32 Bit, Using VMWare v12). However, when i type in command "lmli", that results in the commands shown below:
[localhost@localhost ~]$ cd /home/cadence/ic610
[localhost@localhost ic610]$ lmli
[localhost@localhost ic610]$  7:23:01 (lmgrd) ----------------------------------------------- 7:23:01 (lmgrd)   Please Note:
7:23:01 (lmgrd)
7:23:01 (lmgrd)   This log is intended for debug purposes only.
7:23:01 (lmgrd)   In order to capture accurate license
7:23:01 (lmgrd)   usage data into an organized repository,
7:23:01 (lmgrd)   please enable report logging. Use Macrovision's
7:23:01 (lmgrd)   software license administration  solution,
7:23:01 (lmgrd)   FLEXnet Manager, to  readily gain visibility
7:23:01 (lmgrd)   into license usage data and to create
7:23:01 (lmgrd)   insightful reports on critical information like
7:23:01 (lmgrd)   license availability and usage. FLEXnet Manager
7:23:01 (lmgrd)   can be fully automated to run these reports on
7:23:01 (lmgrd)   schedule and can be used to track license
7:23:01 (lmgrd)   servers and usage across a heterogeneous
7:23:01 (lmgrd)   network of servers including Windows NT, Linux
7:23:01 (lmgrd)   and UNIX. Contact Macrovision at
7:23:01 (lmgrd)   www.macrovision.com for more details on how to
7:23:01 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
7:23:01 (lmgrd)   for your enterprise.
7:23:01 (lmgrd)
7:23:01 (lmgrd)
7:23:01 (lmgrd)
7:23:01 (lmgrd) The TCP port number in the license, 5280, is already in use.
7:23:01 (lmgrd) Possible causes:
7:23:01 (lmgrd)    1) The license server manager (lmgrd) is already running for this license. 7:23:01 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
7:23:01 (lmgrd)    3) Another process is using this port number (unlikely).
7:23:01 (lmgrd) Solutions:
7:23:01 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
7:23:01 (lmgrd)       license are not running.
7:23:01 (lmgrd)    2) You may have to wait for the OS to clear this port.
7:23:01 (lmgrd) Retrying for about 5 more minutes
7:23:19 (lmgrd) Still trying...
7:23:37 (lmgrd) Still trying...
7:23:55 (lmgrd) Still trying...
7:24:13 (lmgrd) Still trying...
7:24:31 (lmgrd) Still trying...
7:24:49 (lmgrd) Still trying...
7:25:07 (lmgrd) Still trying...
7:25:25 (lmgrd) Still trying...
7:25:43 (lmgrd) Still trying...
7:26:01 (lmgrd) Still trying...
7:26:19 (lmgrd) Still trying...
7:26:34 (lmgrd) Failed to open the TCP port number in the license.
Before that, i have installed IC610 and MMSIM v6.1 successfully.
My install directory for ic610 is /home/cadence/ic610
My install directory for mmsim61 is /home/cadence/mmsim61
The name of my machine is localhost
The content at .bashrc for my machine is also shown below:
# .bashrc
alias lmli='/home/cadence/ic610/tools/bin/lmgrd -c /home/cadence/ic610/share/license/license.dat'
# User specific aliases and functions
# Source global definitions
if [ -f /etc/bashrc ]; then
    . /etc/bashrc
fi
export OA_HOME=/home/cadence/ic610/OA
export CDS_ROOT=/home/cadence/ic610
export MMSIM_ROOT=/home/cadence/mmsim61
export CDS_LIC_FILE=5280@localhost
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export CDS_Netlisting_Mode=Analog
export PATH=$MMSIM_ROOT/tools/binMMSIM_ROOT/tools/spectre/binCDS_ROOT/tools/binCDS_ROOT/tools/dfII/bin:$PATH
export MOZILLA_HOME=/usr/bin/netscape
Pls Help!!! Thanks.
发表于 2015-10-12 17:54:55 | 显示全部楼层
you need not  excute daemon like "lmgrd -c license".
You only need to patch like below and CDS_LIC_FILE=license.dat.
./sfk rep -yes -pat -bin /5589E557565381ECD00000008B5508/31C0C357565381ECD00000008B5508/ -bin /5589E557565381ECD8000000E8000000005B81C3/33C0C357565381ECD8000000E8000000005B81C3/ -bin /41574989FF415641554154554889CD534489C3/33C0C389FF415641554154554889CD534489C3/ -dir . -yes
点评
謝謝(你的)信息。我們正在等待新消息  发表于 2023-7-13 08:23
GMT+8, 2025-12-22 21:19 , Processed in 0.017047 second(s), 6 queries , Gzip On, Redis On.
