查看: 8335|回复: 25
[资料] Application note : RF Design Guidelines-PCB Layout and Circuit Optimization
发表于 2013-1-8 21:51:27 | 显示全部楼层 |阅读模式
1 Table of Contents
1 Table of Contents............................................................................................................................2
1.1 Index of Figures .....................................................................................................................2
1.2 Index of Tables ......................................................................................................................2
2 Introduction .....................................................................................................................................3
3 General PCB Layout Techniques ....................................................................................................4
3.1 4-Layer Designs.....................................................................................................................4
3.2 2-Layer Designs.....................................................................................................................5
3.3 PCB Transmission Lines .......................................................................................................6
3.4 Current Loops and Decoupling..............................................................................................7
3.5 PCB Parasitics......................................................................................................................7
4 RF Device PCB Layout and Optimization........................................................................................9
4.1 Thermal Relief Pad ................................................................................................................9
4.2 VCO and Loop Filter ..............................................................................................................9
4.2.1 PCB Layout .......................................................................................................................9
4.2.2 Optimization....................................................................................................................11
4.3 Transmitter Circuit ...............................................................................................................12
4.3.1 Optimization....................................................................................................................12
4.3.2 PCB Layout .....................................................................................................................16
4.4 Receiver LNA Circuit ...........................................................................................................16
4.4.1 PCB Layout .....................................................................................................................16
4.4.2 Circuit Optimization .........................................................................................................17
5 Passive Components .....................................................................................................................20
5.1 Capacitors...........................................................................................................................20
5.2 Inductors ..............................................................................................................................21
Figure 1: Semtech Transceiver Architecture...........................................................................................3
Figure 2: 4-Layer PCB Build-Up .............................................................................................................4
Figure 3: 2-Layer Reference Design.......................................................................................................5
Figure 4: PCB Microstrip Trace...............................................................................................................6
Figure 5: Circuit Decoupling and Current Loop Minimization .................................................................7
Figure 6: PCB Via ..................................................................................................................................8
Figure 7: Multiple Via Connection of Thermal Pad .................................................................................9
Figure 8: VCO Tank Circuit Layout .......................................................................................................10
Figure 9: PLL Loop Filter.......................................................................................................................10
Figure 10: Semtech Loop Filter Configurations ....................................................................................11
Figure 11: TX Matching Network ..........................................................................................................12
Figure 12: Measurement of Optimum Load Impedance Presented to the Transmitter ........................13
Figure 13: Design of Pi-Section Filter ...................................................................................................14
Figure 14: Impedance Transformation..................................................................................................15
Figure 15: Optimized Matching Circuit..................................................................................................15
Figure 16: Transmitter Section PCB Layout .........................................................................................16
Figure 17: LNA Matching Network ........................................................................................................16
Figure 18: LNA PCB Layout..................................................................................................................17
Figure 19: Measurement and Optimization of the LNA Matching network ...........................................18
Figure 20: Optimized LNA Matching Network Input Reflection Coefficient ..........................................18
Figure 21: I and Q Channel Output Signals ..........................................................................................19
Figure 22: Equivalent Circuit of a Multilayer Ceramic Capacitor ..........................................................20
Figure 23: Inductor Equivalent Circuit...................................................................................................21
1.2 Index of Tables
Table 1: Optimum Transmitter Load Impedance ..................................................................................13
Table 2: Typical I, Q Signal Amplitudes ................................................................................................19
Table 3: Typical Decoupling Capacitor Values .....................................................................................20
Table 4: Typical Inductor Types............................................................................................................22
AN.pdf
481.92 KB, 下载次数: 254 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-1-8 22:16:55 | 显示全部楼层
haodogn xi
发表于 2013-1-21 04:16:50 | 显示全部楼层
回复 1# homerican
   Looks good from the content
发表于 2013-2-6 14:47:25 | 显示全部楼层
thanks!
发表于 2013-2-13 20:38:58 | 显示全部楼层
Thanks a lot
发表于 2013-2-17 12:55:15 | 显示全部楼层
kankan
发表于 2013-4-16 18:06:13 | 显示全部楼层
thank you
发表于 2013-4-20 19:36:13 | 显示全部楼层
感谢分享
发表于 2013-4-26 09:20:39 | 显示全部楼层
感谢楼主分享.
发表于 2013-4-26 09:25:52 | 显示全部楼层
have  a  look
GMT+8, 2025-12-21 12:29 , Processed in 0.024154 second(s), 8 queries , Gzip On, Redis On.
