查看: 8884|回复: 2
modelsim simulator problem. Help me. Thanks
发表于 2006-12-27 00:28:24 | 显示全部楼层 |阅读模式
Hi, All,
I meet a question when I use modelsim.
The question is:
After I finished a simulation, I can see signals in the dataflow and waveform windows. Then I save a .wlf file.
Then I closed the modelsim tools. Then I reopen the modelsim again. Then I only open the .wfl file without running others. I can only see signals in waveform windows. I can't see ang signals in dataflow windows yet.And I drag signal from other windows to dataflow windows. It is still nothing. Before I close modelsim, I can see the signals in dataflow windows. But after I close modelsim and reopne modelsim, I can't see anything in dataflow windows.
The tools shows me "Error: Active logfile is not in simulation mode"
Could you give me some suggestion?
Thanks a lot.
发表于 2006-12-30 00:03:42 | 显示全部楼层
请说中文,除非你是外国人;就是你是外国人,在特定的情况下,也请和我说中文。
发表于 2006-12-30 12:36:56 | 显示全部楼层
原帖由 smalldog 于 2006-12-27 00:28 发表
Hi, All,
The question is:
Then I c ...
.wlf 实际上是一个 脚本文件
当你再次打开modelsim时,需要重新点击work lib里得相应模块。弹出 sim窗口,把鼠标点下 想要观测得模块,这是右边得信号列表会列出该模块得所有信号。一般情况下,你想观察这些信号时,需要把他们add to wave。
不过介于你上次已经保存了响应得 wlf文件,只用在default 波形窗口,打开该文件就行了,点restart ,然后 就可以重新 run
[ 本帖最后由 wice67 于 2006-12-30 12:38 编辑 ]
GMT+8, 2025-12-28 09:37 , Processed in 0.032046 second(s), 8 queries , Gzip On, Redis On.
