查看: 10623|回复: 11
[求助] 版图中通孔的个数会不会影响寄生电容?
发表于 2012-12-29 22:50:36 | 显示全部楼层 |阅读模式
请问各位大神,管子的通孔打的越多,寄生电阻越小,会不会意味着寄生电容更大呢?
发表于 2012-12-30 19:48:39 | 显示全部楼层
和Cap没有关系吧
发表于 2012-12-31 16:51:24 | 显示全部楼层
通孔多了会使寄生电容增加的,高速信号的路径,通孔不要太多太密!
发表于 2012-12-31 16:53:30 | 显示全部楼层
其实最好的办法就是你做一小块电路去比较一下,实践得真知
发表于 2012-12-31 20:59:35 | 显示全部楼层
应该是通孔多,寄生电容变小,主要是金属板重叠面积减小,寄生减小
发表于 2012-12-31 23:32:35 | 显示全部楼层
A ---------------
C1==       R1
      |    C3   |
C2==        R2
B ---------------
dumped eqvalent impedance between plate A and B.
R1 and R2 is resistance of via.
C1 and C2 is vertical parastice capacitance between A and B.
C3 is parastice laternal capacitance between several via.
Premise : another via pattern do not have to exist around AB overlap area.
the More via, the more C3.
But, idealy for proper frequency, if R1=R2 and C1=C2,
then we can say V(C)=V(D).
So we can ignore C3 for simplicity.
if R1=R2=R/2, C1=C2=C/2
Between A and B, equvalent impedance Z = R || (1/sC)
R1 = R0/k (k : the number of via)
resistance will be decrease with directly propotitionnal to the nubmer of via.
C1 = C0*(1-k*r) ( r : via area / original overlap area )
capacitance will be propotional with overlap area between A and B.
But it must substract via area.So as more via, as capacitance will be decrease.
Z = R / (1 + sCR) -> low pass function.
Fc = 1/(2pi*Tc)
     Tc = R*C = R0*C0*(1/k-r)
As more via, TC decrease and then Fc will be increase.
So for high frequecy, we need more via and small area of A and B.
回复 支持 4 反对 1
发表于 2013-1-1 19:35:39 | 显示全部楼层
没听说过这种理论,via当然多一点好,阻抗小,电容增加?这个忽略不计。
发表于 2013-1-2 21:33:14 | 显示全部楼层
via 和寄生电感有点关系,Cap可以忽略
发表于 2014-12-18 10:42:19 | 显示全部楼层
回复 6# julise
    分析的很好,总体而言,via越多,寄生电阻越小,寄生电容越小;
发表于 2014-12-18 11:55:03 | 显示全部楼层
自己画几个通孔密度不同的版图,用电磁场工具仿真即可验证。
GMT+8, 2025-12-23 16:38 , Processed in 0.026577 second(s), 6 queries , Gzip On, Redis On.
