查看: 7621|回复: 6
[求助] SystemVerilog program 能不能定义在 module里?
发表于 2012-12-29 12:28:16 | 显示全部楼层 |阅读模式
初学SV, 根据RLM 尝试着把program定义在module里。结果编译失败。如果把program定义移动到module外,编译成功。根据LRM "Program blocks can be nested within modules or interfaces." ,program可以定义在module里,错在了哪里?
  1. Error-[SE] Syntax error
  2.   Following verilog source has syntax error :
  3.   "sv_program.sv", 8: token is 'program'
  4.     program automatic test();
  5.            ^
  6.   System verilog  keyword 'program' is not expected to be used in this
  7.   context.
    复制代码
  1. `timescale 1ns/100ps
  2. module top;
  3.   reg clk;
  5.     initial begin
  6.       for(int j=0; j!=3; j++) begin
  7.         int k = j;
  8.         fork
  9.           $write("j = %0d\n",j);
  10.           $write("k = %0d\n",k);
  11.         join_none
  12.       end
  13.     end
  14.   endprogram
  15.   initial begin
  16.     $display("Hello World");
  17.   end
  18.   test t();
  19. endmodule
    复制代码
 楼主| 发表于 2012-12-29 20:24:54 | 显示全部楼层
用Mentor的工具compile没有问题。但是VCS 会报错。
发表于 2013-1-7 16:56:35 | 显示全部楼层
他们是同级别的!
发表于 2013-1-11 21:51:05 | 显示全部楼层
module和program是同一级别的,把program的定义从module里面拎出来,在module里面例化一个test就ok了,就像例化一个子模块一样。
发表于 2013-12-21 12:11:15 | 显示全部楼层
可以的
`define DIS "hello,world,%d,%h",'h8,5'd15
module test2;
   reg clk;
program automatic test;
  class cov;
    rand bit[4:0] port;
  endclass
  cov cov1;
    covergroup  portcov;
      coverpoint cov1.port{
        bins port[]={[0]};
      bins other[]=default;
    endgroup
  portcov portcovsample;
  initial begin
    portcovsample=new();
    cov1=new();
    repeat(1000) begin
      assert(cov1.randomize());
      $display("port is %d",cov1.port);
      portcovsample.sample();
    end
  end
    initial begin
$display(`DIS);
    repeat(1000) begin
      #10;
      $display("good");
      $stop;
    end
  end
endprogram
endmodule
发表于 2014-9-23 15:07:35 | 显示全部楼层
学习了~~~~
发表于 2018-12-7 00:09:46 | 显示全部楼层
thank
GMT+8, 2025-12-30 08:05 , Processed in 0.020133 second(s), 7 queries , Gzip On, Redis On.
