查看: 11367|回复: 15
電力模擬軟體Plexim Plecs Standalone 3.3.4 x32 x64 + mac OS 免費空間
发表于 2012-12-24 11:20:02 | 显示全部楼层 |阅读模式
name: 電力模擬軟體  Plexim Plecs Standalone
function : 模擬軟體
version : 3.3.4
platform : 分為  x86 32bit , x86-64 , Mac OS
file size : x86 32bit 52M, x64  64M , mac OS我沒用沒抓.
   x32 use crack patch file .
location : 免費空間  , 分享給大家 . 我無法UPLOAD 大FILE 上 eetop, 只能提供空間,
直接給 LINK
x32
http://rapidgator.net/file/65025547
http://ul.to/fak0nhdk
x64
http://uploaded.net/file/kwyeufjn
http://ul.to/kwyeufjn
http://rapidgator.net/file/65025553
MacOSX
http://ul.to/shvtzx2l
http://rapidgator.net/file/65026051
PLECS® Standalone is an autonomous software package for time-domain simulation of power electronic systems. If you want to be independent from other simulation platforms, PLECS Standalone gives you the all-in-one solution for modeling complex electrical circuits and sophisticated controls in a single environment.
Thanks to its optimized engine, PLECS Standalone runs much faster than the PLECS Blockset. With the comprehensive block library, PLECS Standalone offers a cost-effective yet powerful solution for dynamic system simulation in general.
Dedicated solvers
PLECS Standalone comes with an own engine for solving the circuit equations. The user can choose between variable-step and fixed-step solvers. Variable time-step solvers are generally preferred for accurate and efficient simulations, because they adopt the step size during the simulation depending on model dynamics. PLECS Standalone provides optimized implicit and explicit variable-step solvers for stiff and non-stiff systems.
Sampled data systems
The simulation engine allows to model sampled data systems, i.e. discrete systems that change only at distinct times. You can model systems that are sampled periodically or at variable intervals, systems that contain blocks with different sample rates, and systems that mix continuous and discrete blocks.
Interoperability
先前版本
3.2.7 see
http://bbs.eetop.cn/thread-328534-1-1.html
看來沒有重發.
1.zip
228 Bytes, 下载次数: 83 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-12-25 00:20:24 | 显示全部楼层
thank you andy2000a and merry xmas.
发表于 2012-12-26 16:24:29 | 显示全部楼层
unfortunately this one only worked for a couple of days only and then generated a license error message. One has to rewind  the system date to make it working again. The BEAN doctors have never managed to fix that problem. The prog seems to have a time bomb and stops working after some time (a couple of days or a month depending how often the prog is used)
发表于 2013-1-6 10:28:37 | 显示全部楼层
回复 1# andy2000a
    你给的那两个32位的地址都下载不了了,你能不能把32位PLECS standalone 3.3.4的crack.rar文件发到我邮箱啊,935351216@qq.com
发表于 2013-2-10 14:29:57 | 显示全部楼层
So this thing doesn't works hein?
发表于 2013-2-10 14:49:21 | 显示全部楼层
回复 5# canito777
   it doesn't .. it stops with a license error after some time.
发表于 2013-3-5 06:46:14 | 显示全部楼层
Write down that 1.zip is a txt file with the links. There is no need the file to be downloaded.
I started to think that the crack is not made by BEAN but from plexim to popularize their package. It is impossible BEAN nao to be able to crack the SW.
For the moment a stable version is 3.2.3 x32 cracked by the MTCT crack.
发表于 2013-3-19 14:37:20 | 显示全部楼层
破解文件有吗?
发表于 2013-5-16 03:16:42 | 显示全部楼层
Great post .But the lic is BADD!
发表于 2014-2-13 19:39:59 | 显示全部楼层
求 licence 。谢谢
GMT+8, 2025-12-26 18:38 , Processed in 0.028103 second(s), 8 queries , Gzip On, Redis On.
