楼主: jackzhang
Modelsim 的使用
发表于 2003-11-27 08:26:47 | 显示全部楼层
Modelsim 的使用
其实加载变量到wave窗口下,只要用以下命令就行了,
add wave -r /*
也可以用signal窗口下的add菜单也可行
发表于 2003-11-27 09:32:32 | 显示全部楼层
Modelsim 的使用
当我在simulation菜单加载*.sdf文件时出现如下错误:
# Loading D:/document/sim/addsim/work/add_vhd.sdo
# ** Error: (vsim-SDF-3250) D:/document/sim/addsim/work/add_vhd.sdo(41): Failed to find INSTANCE '/add/clk_aI/asynch_inst'.
# ** Error: (vsim-SDF-3250) D:/document/sim/addsim/work/add_vhd.sdo(50): Failed to find INSTANCE '/add/b_aI/asynch_inst'.
# ** Error: (vsim-SDF-3250) D:/document/sim/addsim/work/add_vhd.sdo(59): Failed to find INSTANCE '/add/a_aI/asynch_inst'.
# ** Error: (vsim-SDF-3250) D:/document/sim/addsim/work/add_vhd.sdo(68): Failed to find INSTANCE '/add/rst_aI/asynch_inst'.
# ** Error: (vsim-SDF-3250) D:/document/sim/addsim/work/add_vhd.sdo(77): Failed to find INSTANCE '/add/c_areg0_I/lecomb'.
# ** Warning: (vsim-SDF-3432) D:/document/sim/addsim/work/add_vhd.sdo: This file is probably applied to the wrong instance.
# Ignoring subsequent missing instances from this file.
# ** Warning: (vsim-SDF-3440) D:/document/sim/addsim/work/add_vhd.sdo: Failed to find any of the 7 instances from this file.
# ** Warning: (vsim-SDF-3443) D:/document/sim/addsim/work/add_vhd.sdo: This file is probably intended for an instance at a lower level, not the top level.
# ** Error: (vsim-SDF-3445) Failed to parse SDF file "D:/document/sim/addsim/work/add_vhd.sdo".
#    Time: 0 ns  Iteration: 0  Region: /add  File: D:/document/sim/addsim/work/add.vhd
# Error loading design
这是什么原因啊,
不过我的程序中没有测试程序.是不是这个原因的,不是说用modelsim只要载入*.vhdl和*.sdf文件就可以吗?
发表于 2003-11-27 09:53:43 | 显示全部楼层
Modelsim 的使用
下面引用由songyang2003/11/27 09:32am 发表的内容:
当我在simulation菜单加载*.sdf文件时出现如下错误/document/sim/addsim/work/add_vhd.sdo
# ** Error/document/sim/addsim/work/add_vhd.sdo(41): Failed to find INSTANCE '/add/clk_aI/asynch_inst'.
# ** Er ...
可能是sdo文件的作用范围没有指定。如果是这个原因,参考下面连接:
http://www.eetop.com.cn/cgi-bin/ ... pic=718&show=25
发表于 2003-11-28 10:21:30 | 显示全部楼层
Modelsim 的使用
SE vhdl simulator license (vsim)
A license was found and will expire on 1-jan-2020 (5878 days).
SE verilog simulator license (vsim-vlog)
SE language neutral simulator license (hdlsim)
SE language neutral simulator mix license (hdlmix)
Performance Analyzer license (vsim-profile)
Code Coverage license (vsim-coverage)
Waveform Viewer license (vsim-viewer)
Waveform Compare license (vsim-compare)
Dataflow Window license (dataflow)
vhdl_opt license (vhdl_opt)
verilog_opt license (verilog_opt)
license wizard完了,出来上面这个,正常吧!
发表于 2003-12-4 13:21:04 | 显示全部楼层
Modelsim 的使用
FEATURE hdlmix modeltech 2020.0001 1-jan-2020 0 ECEF15352344420ED33F HOSTID=00b0d0fccfe3
FEATURE hdlsim modeltech 2020.0001 1-jan-2020 0 CC5FF5C5FA421A1FA868 HOSTID=00b0d0fccfe3
FEATURE hdlsim2 modeltech 2020.0001 1-jan-2020 0 4C7F25D55192B364C8B2 HOSTID=00b0d0fccfe3
FEATURE verilog_opt modeltech 2020.0001 1-jan-2020 0 FCCFB5F527FBA1E4F20C HOSTID=00b0d0fccfe3
FEATURE vhdl_opt modeltech 2020.0001 1-jan-2020 0 CCAFB515B14D2EC1655D HOSTID=00b0d0fccfe3
FEATURE vsim modeltech 2020.0001 1-jan-2020 0 4CEF75C5E71ECCB6993E HOSTID=00b0d0fccfe3
FEATURE dataflow modeltech 2020.0001 1-jan-2020 0 DC1FF525746B72703694 HOSTID=00b0d0fccfe3
FEATURE vsim-compare modeltech 2020.0001 1-jan-2020 0 3C6FF5953F22CE7090B2 HOSTID=00b0d0fccfe3
FEATURE vsim-coverage modeltech 2020.0001 1-jan-2020 0 9C2F558566BD00C1AB8B HOSTID=00b0d0fccfe3
FEATURE vsim-profile modeltech 2020.0001 1-jan-2020 0 CCBFE5D5A535CA6EB0BE HOSTID=00b0d0fccfe3
FEATURE vsim-viewer modeltech 2020.0001 1-jan-2020 0 4C6FC5752F2891C85827 HOSTID=00b0d0fccfe3
FEATURE vsim-vlog modeltech 2020.0001 1-jan-2020 0 8C3F55452EF2CBCF869B HOSTID=00b0d0fccfe3
我的license,大家看看缺补缺?
 楼主| 发表于 2003-12-5 15:49:56 | 显示全部楼层
Modelsim 的使用
license 没有问题
发表于 2003-12-5 16:24:19 | 显示全部楼层
Modelsim 的使用
郁闷!wave窗口不能加载数据
 楼主| 发表于 2003-12-5 16:26:46 | 显示全部楼层
Modelsim 的使用
没办法,你换一台机子在试试吧。
发表于 2004-2-20 17:45:28 | 显示全部楼层
Modelsim 的使用
哈哈,modelsim编译通过了,并不代表能够综合萨.
所以,dc还是汇报错的萨
发表于 2005-3-26 23:59:50 | 显示全部楼层
Modelsim 的使用
收藏
GMT+8, 2025-12-19 12:44 , Processed in 0.026259 second(s), 4 queries , Gzip On, Redis On.
