查看: 11617|回复: 3
[求助] Verilog里面的乘法、求模、除法
发表于 2012-12-16 15:08:16 | 显示全部楼层 |阅读模式
请问这三个运算是如何实现的?是调用FPGA内部已经有的硬件运算单元吗?自己写的乘法器跟直接用*做乘法有什么区别?
发表于 2012-12-16 18:52:01 | 显示全部楼层
这个基本都是LUT,相当于一个ram,两个乘数因子构成地址,一个时钟就能输出
如果你自己写个乘法器,再怎么处理你看多少时钟周期才能输出
发表于 2012-12-16 19:36:48 | 显示全部楼层
There are many ways to implement a multiplier or a divider. If you have small operand size (for example, 8bit) then you can probably do that with LUT that store all possible outcomes in a ROM. however, if you have big operand size (for example, 32bit) then you might need a good algorithm to do that. A popular circuit synthesizer (for example, DC) has already implemented optimized algorithms in its database and you don't have to implement your own. Just write * or / in your RTL will do.
发表于 2017-6-30 10:32:25 | 显示全部楼层
回复 3# apyamy
Are you kidding me?
GMT+8, 2025-12-30 01:26 , Processed in 0.019745 second(s), 7 queries , Gzip On, Redis On.
