查看: 6514|回复: 5
[求助] 这个def文件怎么改成Verilog-A文件?
发表于 2012-12-14 15:49:13 | 显示全部楼层 |阅读模式
用spectre仿真时,模型库里有个res.def文件,看名字是电阻模型定义文件,但仿真的时候总是出错,
提示:
      FATAL (VACOMP-2096): File '/home/Cadence/../models/spectre/res.def' does not appear to be a valid Verilog-A file. In previous releases, '.def' was a file extension typically used for SpectreHDL files but SpectreHDL is no longer supported. If this file is a SpectreHDL file, you need to replace it with an equivalent Verilog-A file.
怎样才能转换为Verilog-A格式的文件呢?求各位不吝赐教~~谢谢了
res.def 内容如下:
module polyres_hdl (n2, n1, ctrl2, ctrl1) (wr, lr, vc1, vc2, rtemp, tc1, tc2, etch, tnom, rsh0)
node [V, I] n2, n1, ctrl2, ctrl1;
parameter real lr=0.0;
parameter real wr=0.0;
parameter real rtemp=$temp() - 273.15;
parameter real vc1 = 0;
parameter real vc2 = 0;
parameter real tc1 = 0;
parameter real tc2 = 0;
parameter real etch = 0;
parameter real tnom = 25.0;
parameter real rsh0 = 1;
real dt, absv, tcoef, vcoef, r0;
    initial
    analog
    {   dt = (rtemp - tnom);
        absv = abs(V(ctrl2, ctrl1));
tcoef = 1.0 + dt * (tc1 + dt * tc2);
vcoef = 1.0 + absv * (vc1 + absv * vc2);
r0 = rsh0 * lr / ( wr - 2.0 * etch ) * tcoef * vcoef;
V(n2, n1) <- I(n2, n1) * r0;
    final
module diffres_hdl (n2, n1, ctrl2, ctrl1) (wr, lr, rtemp, vc1, vc2, tc1, tc2, etch, tnom, rsh0)
    initial
    analog
        absv = V(ctrl2, ctrl1);
    final
 楼主| 发表于 2012-12-16 16:20:34 | 显示全部楼层
有人么有人么。。
发表于 2014-4-28 16:20:46 | 显示全部楼层
同问。。楼主解决了么。。
 楼主| 发表于 2014-4-29 14:14:14 | 显示全部楼层
回复 3# win9401
我是找工艺厂家要了一个替换文件,复制过去就可以正常用了,你也可以去厂家问问。
发表于 2016-5-21 19:49:24 | 显示全部楼层
发表于 2016-6-28 23:20:30 | 显示全部楼层
楼主,可否把你向厂家要的文件已发我一份你,我邮箱1172730448@qq.com,万分感谢!!
GMT+8, 2025-12-25 21:29 , Processed in 1.363866 second(s), 6 queries , Gzip On, Redis On.
