查看: 10075|回复: 2
[求助] 使用SMIC018数字库遇到的问题,求牛人们帮忙解决一下吧
发表于 2012-12-12 21:57:00 | 显示全部楼层 |阅读模式
Setp1:
打开Astro,新建Milkyway Lib,添加.tf文件,选中developer,casesensitive选项,提示错误如图1[img]file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/642352444/QQ/WinTemp/RichOle/38JS(~60(2J7CLWSWFM@TZ7.jpg[/img]
Step2:
添加GDS文件。添加GDS,gds2ARC.map和gds2InLayer.map文件,没有提示错误
Setp3:
添加LEF文件。添加cell lef文件,没有添加layer mapping文件,这个好像没有提供。提示错误如下2 file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/642352444/QQ/WinTemp/RichOle/I2EMZCT`9ZRY])WJ0T5I`EN.jpg
这个时候已经有了CEL view 和FRAM view, [img]file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/642352444/QQ/WinTemp/RichOle/@SEJ42AV`W[A[$(WJ$PDV1E.jpg[/img]
Step5:
上面明显不正确,所以又重新添加了一个PILB文件,添加cell plib文件和GDS文件,提示错误如下5
但是这个时候打开CELL layout明显好多了,看起来比较完整了
之后打开ICC,运行脚本总是提示下面的错误,不管怎么修正脚本都是,所以我觉得一定是建库有问题。
Warning: Should load physical library before reading this design, which has physical information.
Error: Cannot find site in physical lib with w=660, h=5040
Error: Floorplan loading cannot read site array and core area.
Error: Unable to get layer METAL3 in physical library.
Error: Unable to get layer METAL2 in physical library.
Error: Floorplan loading port location/shape failed.
Error: Floorplan loading failed.
Error: No floorplan is defined for the current design for non-mpc or incremental physical synthesis. (PSYN-080)
Error: extract_rc has abnormally terminated.  (OPT-100)
 楼主| 发表于 2012-12-12 22:01:59 | 显示全部楼层
回复 1# malin2011
1.file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/642352444/QQ/WinTemp/RichOle/O22(NL$C1RY$FE(GPOD2LNF.jpg
 楼主| 发表于 2012-12-12 22:11:53 | 显示全部楼层
回复 2# malin2011
    2.
GMT+8, 2025-12-24 21:42 , Processed in 0.165911 second(s), 7 queries , Gzip On, Redis On.
