查看: 25683|回复: 22
[求助] MMSIM7.2 license问题——waiting for available license for virtuoso spectre
发表于 2012-12-6 14:49:51 | 显示全部楼层 |阅读模式
装的MMSIM7.2,.bashrc设置好之后icfb打开正常,到了仿真运行的时候出现下面这个错误,看上去应该是licence的问题,但我的licence是从本论坛下载的,对应MMSIM7.2,而且需要修改的路径也改过了,但还是不能用。
仿真错误
仿真错误
license.dat内容:
#SERVER localhost.localdomain ANY 5280
#DAEMON cdslmd /home/Cadence/eda/tools/bin/cdslmd  **/home/Cadence/eda是我MMSIM7.2的安装路径
FEATURE 91100 cdslmd 1000.0000 permanent uncounted \
        DD64ADDC83ADB45F0A9C VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=50 SIGN2="10A2 D796 7F12 A424 6344 27D4 2ED7 B6D3 2595 D6B1 \
        8455 DA23 50A8 6B4F 66AD 1DC1 EA45 758B 5393 B0DA 5509 10A7 \
        2186 CD61 E09D 3DF4 48B1 4BA1 FDF9 354B"
FEATURE 91200 cdslmd 1000.0000 permanent uncounted \
        3D045DBC5D1F11B2DBC5 VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=75 SIGN2="0B02 2BD8 9EE4 1F09 D169 1076 C4D5 A54C 90CE 774A \
        A658 C855 54C3 07C3 C8C4 1BDC 4CC9 7184 E5BA C47D 1E09 9E87 \
        1E08 9C67 20E0 5EFB 8E2B B401 BBF9 2392"
FEATURE 90002 cdslmd 1000.0000 permanent uncounted \
        DD64FD4C83BCB6C0187F VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=122 SIGN2="01BC 2146 205C 3789 2DAA 89CE D538 CC4A 6A73 \
        6CC3 8099 76C7 E49D 4DB0 7195 19FC B217 6A48 848E FFA4 F8B1 \
        3BD7 63E9 F5CE 77BE CED9 D66F 76C9 F53A 1CC1"
FEATURE 90003 cdslmd 1000.0000 permanent uncounted \
        7D545D5C831CB6C2B77E VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=64 SIGN2="0A8C C9B0 1F24 CDA1 46E1 E6F6 FD6E 9003 D588 48C8 \
        2F90 21E8 6211 3FC9 7718 1D79 8B6B 0872 975B 91E5 F2C2 1F8F \
        E591 4E85 42C0 5729 E429 8990 3514 4184"
FEATURE Virtuoso_Acceler_Parallel_L cdslmd 1000.0000 permanent \
        uncounted CD44BD7C40B331A4E009 VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=132 SIGN2="0688 EEFD 1AEB D622 B6BA F0C2 F594 \
        0FE7 7C81 6472 A89E F60F BE0D A0E5 A6EA 015F 84F5 7ABD 4C2A \
        BE54 DA41 64C4 635F B7E7 289E BBF7 E66A BC0E FDB4 3359"
FEATURE Virtuoso_Acceler_Parallel_XL cdslmd 1000.0000 permanent \
        uncounted FD44ED8CC83DBE739A56 VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=135 SIGN2="198F EE54 E874 E97C 0638 5AC3 5985 \
        C45C 28FE 1240 65DB 7ECE FB0F 2B1C 21ED 1187 1D52 E418 190E \
        22C3 EEB4 C4C7 DB43 CEBA FAB8 AF26 B8DB 6A93 A594 011B"
FEATURE Virtuoso_Multi_mode_Simulation cdslmd 1000.0000 permanent \
        uncounted 5DF48DFC3A03C362E6B2 VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=57 SIGN2="0A29 BB28 2C87 926F 18CC 326D 2A32 \
        B841 7EDC 6D23 4034 7805 CFE9 9353 5B2C 1F10 5D7F 55F2 7FD6 \
        BB3A 1720 6B7E 4AEA 3E72 28AB 9DBD 087E D98D 3361 C8D6"
FEATURE Virtuoso_APS_MMSIM_Lk cdslmd 1000.0000 permanent uncounted \
        4DC44D2CB20263B01B48 VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=46 SIGN2="06A7 A26D 2951 1E0F 56D5 E852 3E7C B417 0FB8 2DA2 \
        1721 F371 A895 BC3C 0B44 0E9A 5C7E 9FC2 ABED 0FF1 8F93 4885 \
        0E5D 4112 9F02 33A9 BC14 948A 7325 6A3A"
FEATURE Virtuoso_Spectre_GXL_MMSIM_Lk cdslmd 1000.0000 permanent \
        uncounted ED947D5C4B3472704D76 VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=10 SIGN2="1A1F BBFC D4E0 A50B 9E30 999F 85B6 \
        25DB ACB6 7C94 B2D6 A508 870F B6A4 A61A 04D9 8172 99D1 6A1B \
        5ECC 21F9 1A4C 4B88 1E04 51A3 84AF 11A7 A80A 61D9 E1C4"
 楼主| 发表于 2012-12-6 14:55:33 | 显示全部楼层
求各位大神指教~
 楼主| 发表于 2012-12-6 22:55:06 | 显示全部楼层
求指教啊求指教。。
 楼主| 发表于 2012-12-7 14:55:27 | 显示全部楼层
求指教啊,捉急
 楼主| 发表于 2012-12-8 21:50:31 | 显示全部楼层
找到问题了,居然是因为没有破解成功,把patch_cadence文件和sfk文件拷到MMSIM72安装目录下,./patch_cadence等到破解完成再重启虚拟机就OK了。
发表于 2014-1-14 14:23:13 | 显示全部楼层
回复 5# liufengchun100
   有用。
发表于 2014-1-21 18:18:12 | 显示全部楼层
貌似找不到 可以破解64bit MMSIM7.2的patch
发表于 2014-2-12 11:05:04 | 显示全部楼层
where can i find the patch?
Thank you
 楼主| 发表于 2014-2-13 08:46:41 | 显示全部楼层
回复 8# maverick28229
    论坛里很多的,你找一个试试
发表于 2014-3-27 22:29:56 | 显示全部楼层
   必须要重启虚拟机吗?
GMT+8, 2025-12-24 17:17 , Processed in 0.025540 second(s), 6 queries , Gzip On, Redis On.
