查看: 8009|回复: 9
[调查] Verilog_XL加密的文件如何解密呢
发表于 2012-12-3 20:22:18 | 显示全部楼层 |阅读模式
verilog_xl可以用·protect和·endprotect来加密源代码,那么怎么解密呢,有木有大牛知道呀?谢谢
发表于 2012-12-4 09:46:44 | 显示全部楼层
The content between "protect begin" and "protect end" is encrypted using 256-bit AES algorithm.Usually it's unbreakable unless you know the encryption KEY.
发表于 2012-12-4 16:38:08 | 显示全部楼层
楼上的意见正确。哈哈
 楼主| 发表于 2012-12-4 19:57:05 | 显示全部楼层
回复 2# apyamy
    谢谢,如何得到这样的key呢
发表于 2012-12-5 10:17:51 | 显示全部楼层
回复 4# fl_5588
Ask those who provide you the protected codes. The protected codes are created using a tool which requires users to enter the KEY.
If they do not enter any KEY, the tool will generate a default KEY using proprietary algorithm.
Unfortunately, I don't know such algorithm and can't help you.
 楼主| 发表于 2012-12-5 15:21:52 | 显示全部楼层
回复 5# apyamy
    已经很好了,十分感谢!!
发表于 2012-12-7 17:33:23 | 显示全部楼层
 楼主| 发表于 2012-12-7 22:20:41 | 显示全部楼层
回复 7# see123
    怎么查看源文件呢?
 楼主| 发表于 2012-12-7 23:00:56 | 显示全部楼层
回复 7# see123
    怎么查看源文件呢?
发表于 2016-1-5 09:42:49 | 显示全部楼层
学习了
GMT+8, 2025-9-15 05:22 , Processed in 0.018802 second(s), 5 queries , Gzip On, Redis On.
