查看: 6927|回复: 10
Verdi2011安装license.dat文件求助!
发表于 2012-12-3 15:56:08 | 显示全部楼层 |阅读模式
最近安装EDA的系列软件,VCS勉强搞定之后,再装debug软件Verdi,从imap的帖子
Verdi 2011-04 Basic:http://bbs.eetop.cn/viewthread.php?tid=300023&;
Verdi 2011-04 Linux:http://bbs.eetop.cn/viewthread.php?tid=300052&;
Verdi 2011-04 Doc / Demo etc:http://bbs.eetop.cn/viewthread.php?tid=300648&;
Verdi 2011-04 Linux64:http://bbs.eetop.cn/viewthread.php?tid=300083&;
下载了整套的Verdi2011,解压之后唯独欠缺一个破解可用的license.dat,希望eetop的各位大牛给小弟指点一二,折腾了这么久,真的不想半途而废啊!
PS:之前尝试安装了Verdi2009的版本(未成功)错误提示为:各位能帮我解决Verdi2009的问题,小弟也是不甚感激!
12:38:43 (lmgrd) Possible causes:
12:38:43 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
12:38:43 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
12:38:43 (lmgrd)    3) Another process is using this port number (unlikely).
12:38:43 (lmgrd) Solutions:
12:38:43 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
12:38:43 (lmgrd)       license are not running.
12:38:43 (lmgrd)    2) You may have to wait for the OS to clear this port.
12:38:43 (lmgrd) Retrying for about 5 more minutes
12:38:47 (lmgrd) The TCP port number in the license, 28001, is already in use.
12:38:47 (lmgrd) Possible causes:
12:38:47 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
12:38:47 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
12:38:47 (lmgrd)    3) Another process is using this port number (unlikely).
12:38:47 (lmgrd) Solutions:
12:38:47 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
12:38:47 (lmgrd)       license are not running.
12:38:47 (lmgrd)    2) You may have to wait for the OS to clear this port.
12:38:47 (lmgrd) Retrying for about 5 more minutes
12:39:01 (lmgrd) Still trying...
12:39:05 (lmgrd) Still trying...
12:42:16 (lmgrd) Failed to open the TCP port number in the license.
12:42:20 (lmgrd) Failed to open the TCP port number in the license.
 楼主| 发表于 2012-12-3 16:00:56 | 显示全部楼层
Verdi2009的版本,我用TCP Port为28001(Crack默认的)和其他的Port都无法看到论坛里面各位提到的提示:
using TCP-port xxxxx
总之一个苦逼啊!
发表于 2012-12-5 08:43:06 | 显示全部楼层
Did you use the port for other software ?
发表于 2012-12-5 09:54:08 | 显示全部楼层
Search the CK file in the bbs!
 楼主| 发表于 2012-12-7 12:10:46 | 显示全部楼层
回复 3# pupukid
   本来是用的跟Synopsys一样的27000,后来换了其他的Port,还是不行。不过换了论坛上的另外一个2011.01的版本的可以用了,那个版本不需要license文件,一个patch就搞定了,还是谢谢你了!
 楼主| 发表于 2012-12-7 12:11:44 | 显示全部楼层
回复 4# 飞扬紫百合
   换了论坛上的另外一个2011.01的版本,可以用了,不过还是谢谢你了!!!
发表于 2014-4-8 17:46:42 | 显示全部楼层
lz问题怎么解决啊?求助?
发表于 2014-4-30 10:30:04 | 显示全部楼层
楼主怎么解决的,求安装教程和破解方法~
发表于 2014-5-12 11:49:28 | 显示全部楼层
楼主后来破解成功了吗??我也在下载
发表于 2014-8-3 12:47:52 | 显示全部楼层
怎样加patch啊?
GMT+8, 2025-12-21 06:43 , Processed in 0.022229 second(s), 6 queries , Gzip On, Redis On.
