查看: 18987|回复: 2
Cadence ic610 启动时CIW的报错
发表于 2012-12-1 05:52:51 | 显示全部楼层 |阅读模式
CADENCE启动没有问题,但是输入icfb &之后,CIW过一段时候会开始报错,是关于那个 .cdsinit文件的。我已经将.../tools/dfII/samples/local 拷到 .../tools/dfII里面,并且也把得到的.../tools/dfII/local里那个cdsinit改名为.cdsinit 。这个报错不影响我使用CADENCE,但是这么多错误实在让人费解。请求牛人帮助解决,thanks a ton.
具体报错引用如下:
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program:  @(#)$CDS: virtuoso.exe version 6.1.0 10/10/2006 14:09 (cds126047) $
Sub version:  sub-version IC6.1.0.243 (32-bit addresses)
Loading geView.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ams.cxt
*Error* lineread/read: syntax error encountered in input
*Error* eval: undefined function - dfII
   This file should be copied as <cds_install_dir>/local/.cdsinit
SYNTAX ERROR found at line 5 column 59 of file .cdsinit
*Error* eval: unbound variable - customized
*WARNING* (reader): suspicious newline found after the operator .
   read and executed when the Design Framework II software starts.
SYNTAX ERROR found at line 7 column 66 of file .cdsinit
*Error* eval: undefined function - This
   application bind key files.
SYNTAX ERROR found at line 10 column 31 of file .cdsinit
     ./.cdsinit - .cdsinit in the working directory
SYNTAX ERROR found at line 20 column 8 of file .cdsinit
     ~/.cdsinit - .cdsinit in the user's home directory
SYNTAX ERROR found at line 21 column 8 of file .cdsinit
   This site file checks if a .cdsinit exists in the working directory
SYNTAX ERROR found at line 23 column 32 of file .cdsinit
   and executes it. If .cdsinit does not exist in the user's working
SYNTAX ERROR found at line 24 column 25 of file .cdsinit
   directory then ~/.cdsinit is executed if it exists.
SYNTAX ERROR found at line 25 column 21 of file .cdsinit
SYNTAX ERROR found at line 28 column 67 of file .cdsinit
*Error* eval: undefined function - Please
*Error* eval: undefined function - customizing
   for a list of sample files supplied.
SYNTAX ERROR found at line 31 column 39 of file .cdsinit
*Error* eval: undefined function - There
*Error* eval: unbound variable - relevant
   be loaded if you want bind keys defined for that application.
SYNTAX ERROR found at line 35 column 64 of file .cdsinit
   See section LOAD APPLICATION BIND KEY DEFINITIONS.
SYNTAX ERROR found at line 36 column 53 of file .cdsinit
SYNTAX ERROR found at line 37 column 67 of file .cdsinit
*Error* eval: undefined function - In
   X resource must be set in the .Xdefaults or .xresources file
SYNTAX ERROR found at line 40 column 35 of file .cdsinit
   pertaining to your hardware platform.
SYNTAX ERROR found at line 41 column 40 of file .cdsinit
*Error* eval: unbound variable - Mwm
*Error* eval: undefined function - After
*Error* eval: unbound variable - xrdb
   and restart the Motif window manager.
SYNTAX ERROR found at line 49 column 40 of file .cdsinit
*Error* eval: undefined function - adds
*Error* eval: undefined function - For
   string.
SYNTAX ERROR found at line 57 column 10 of file .cdsinit
   follow.
SYNTAX ERROR found at line 59 column 10 of file .cdsinit
   independant of the exact installation path.
SYNTAX ERROR found at line 61 column 46 of file .cdsinit
   The function let() creates local variables ( example: libPath ).
SYNTAX ERROR found at line 63 column 68 of file .cdsinit
   This makes sure that any global variables are not accidentally modified.
SYNTAX ERROR found at line 64 column 75 of file .cdsinit
SYNTAX ERROR found at line 66 column 2 of file .cdsinit
*WARNING* too many lookahead chars being pushed back, may lose input.
END OF SITE CUSTOMIZATION
hiCaughtControlC
Loading st02/libInit.il ...
Loading st02/loadCxt.ile ... done!
Loading context 'st02' from library 'st02' ... done!
Loading context 'pdkUtils' from library 'st02' ... done!
Loading st02/.cdsenv ... done!
Loading st02/display.drf ...
done!
Loaded st02/libInit.il successfully!
发表于 2015-5-29 15:41:59 | 显示全部楼层
没有人解释一下为什么吗?怎样解决这个错误啊?
发表于 2018-1-3 14:55:16 | 显示全部楼层
提醒下,你看下启动的路径有没有乱码。比如,你新加一个TF工艺文件,你看下选择的时候他的路径是不是有乱码的字符。
GMT+8, 2025-12-29 04:40 , Processed in 0.017800 second(s), 6 queries , Gzip On, Redis On.
