查看: 7356|回复: 7
[求助] 装DC有点问题请教一下大神
发表于 2012-11-28 00:25:39 | 显示全部楼层 |阅读模式
按照论坛上的DC200809的安装流程装的
输入
lmstat-c /usr/synopsys/license/synopsys.dat
或者
                        lmgrd-c /usr/synopsys/license/synopsys.dat
得到的信息跟教程里面的安装流程中写的也是一样的
输入design_vision 会出现:
Unable to obtain feature 'Design-Vision ' because:
Error: Can't communicate with the license server. (SEC-12)
Please contact  at root@(none), who is
your local Synopsys license administrator for Synopsys site 000.
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
lmgrd-c /usr/synopsys/license/synopsys.dat -l ~/syn_lic.log
之后的log文件是这样子的:
23:40:17 (lmgrd) -----------------------------------------------
23:40:17 (lmgrd)   Please Note:
23:40:17 (lmgrd)
23:40:17 (lmgrd)   This log is intended for debug purposes only.
23:40:17 (lmgrd)   In order to capture accurate license
23:40:17 (lmgrd)   usage data into an organized repository,
23:40:17 (lmgrd)   please enable report logging. Use Macrovision's
23:40:17 (lmgrd)   software license administration  solution,
23:40:17 (lmgrd)   FLEXnet Manager, to  readily gain visibility
23:40:17 (lmgrd)   into license usage data and to create
23:40:17 (lmgrd)   insightful reports on critical information like
23:40:17 (lmgrd)   license availability and usage. FLEXnet Manager
23:40:17 (lmgrd)   can be fully automated to run these reports on
23:40:17 (lmgrd)   schedule and can be used to track license
23:40:17 (lmgrd)   servers and usage across a heterogeneous
23:40:17 (lmgrd)   network of servers including Windows NT, Linux
23:40:17 (lmgrd)   and UNIX. Contact Macrovision at
23:40:17 (lmgrd)   www.macrovision.com for more details on how to
23:40:17 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
23:40:17 (lmgrd)   for your enterprise.
23:40:17 (lmgrd)
23:40:17 (lmgrd)
23:40:17 (lmgrd)
23:40:17 (lmgrd) Can't open /usr/tmp/.flexlm/lmgrdl.9914, errno: 13
23:40:17 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_re3) started on ubuntu (linux) (11/27/2012)
23:40:17 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
23:40:17 (lmgrd) US Patents 5,390,297 and 5,671,412.
23:40:17 (lmgrd) World Wide Web:  http://www.macrovision.com
23:40:17 (lmgrd) License file(s): /usr/synopsys/license/synopsys.dat
23:40:17 (lmgrd) lmgrd tcp-port 27000
23:40:17 (lmgrd) The license server manager has found no vendor daemons to start
23:40:17 (lmgrd)  (There are no VENDOR (or DAEMON) lines in the license file),
lmgrd exiting.
好像是说某个文件打不开的样子
这种情况怎么做?
在坛子上搜了一下,也没搜到什么结果……
遂来请教一下 大神 谢谢
23:40:17 (lmgrd) Can't remove statfile /usr/tmp/.flexlm/lmgrdl.9914: errno No such file or directory
发表于 2012-11-28 12:24:58 | 显示全部楼层
license里面没有写对
发表于 2012-11-29 00:03:58 | 显示全部楼层
回复 1# hukangha
   检查license   另外就是到user里新建tmp文件夹,要用root
发表于 2012-11-29 07:56:12 | 显示全部楼层
它指出你的license內文少VENDOR lines,類似如下所示:
VENDOR snpslmd /path_to/snpslmd
 楼主| 发表于 2012-11-29 23:06:53 | 显示全部楼层
回复 4# mhleu
搞定了谢谢了。你也看绿箭啊
发表于 2013-6-27 19:46:47 | 显示全部楼层
回复 5# hukangha
大侠,你是怎么搞定的?直接在license里面加一行VENDOR snpslmd /path to/snpslmd吗
发表于 2016-3-17 10:59:56 | 显示全部楼层
回复 6# shilei2857
    对的,我添加如下内容后解决:
  1. VENDOR snpslmd PATH_TO_SCL/linux/bin/snpslmd
    复制代码
发表于 2016-3-17 11:27:03 | 显示全部楼层
顶起~~祝楼主开心~
GMT+8, 2025-12-14 03:34 , Processed in 0.023838 second(s), 7 queries , Gzip On, Redis On.
