查看: 3881|回复: 1
[求助] 在ISE10.1中tb调用 modelsim,说找不到编译库?怎么解决?我用的FFTs的IP核
发表于 2012-11-27 15:46:55 | 显示全部楼层 |阅读模式
在ISE10.1中tb调用 modelsim,说找不到编译库?怎么解决?我用的FFTs的IP核 Instantiation of 'ofdm_fft' failed. The design unit was not found.,怎么解决的,我仿真别的成功了啊?具体错误如下Loading work.ofdm_modu
# ** Error: (vsim-3033) ofdm_modu.v(67): Instantiation of 'ofdm_fft' failed. The design unit was not found.
#         Region: /ofdm_modu
#         Searched libraries:
#             f:\Xilinx\ISE\verilog\mti_se\XilinxCoreLib_ver
#             f:\Xilinx\ISE\verilog\mti_se\unisims_ver
#             f:\Xilinx\ISE\verilog\mti_se\unimacro_ver
#             D:\xilinx_project\ofdm_modem\ofdm_modem\work
# Loading work.glbl
# Error loading design
发表于 2012-11-27 22:13:40 | 显示全部楼层
在ISE中有个compile HDL Simulation Libraries选项
compile一下就OK,不过时间有点长,耐心等吧
GMT+8, 2025-12-15 01:33 , Processed in 0.018162 second(s), 5 queries , Gzip On, Redis On.
