查看: 13170|回复: 34
[资料] soc热点---温度控制 thermal control
发表于 2012-11-21 19:06:42 | 显示全部楼层 |阅读模式
System-Level Dynamic Thermal Management for High-Performance Microprocessors..pdf (608.79 KB , 下载次数: 58 )
Techniques for Multicore Thermal Management Classification and New Exploration.pdf (412.04 KB , 下载次数: 37 )
Temperature Aware Task Scheduling in MPSoCs..pdf (185.9 KB , 下载次数: 39 )
abbr_a0e6db28f54caedc9376341df4544279.pdf (288.38 KB , 下载次数: 18 )
abbr_79dd8406cb51f76d651e65daea835543.pdf (1.92 MB , 下载次数: 58 )
Temperature-aware processor frequency assignment for MPSoCs using convex optimization.pdf (196.8 KB , 下载次数: 20 )
Temperature-Aware Voltage Selection for Energy Optimization..pdf (254.01 KB , 下载次数: 29 )
Temptor A Lightweight Runtime Temperature Monitoring Tool Using Performance Counters..pdf (270.15 KB , 下载次数: 11 )
Temptor A Lightweight Runtime Temperature Monitoring Tool Using Performance Counters.pdf (270.15 KB , 下载次数: 6 )
Thermal Analysis of Multiprocessor SoC Applications by Simulation and Verfication..pdf (1.27 MB , 下载次数: 40 )
Thermal aware task sequencing on embedded processors..pdf (541.36 KB , 下载次数: 14 )
Thermal effects of leakage power in 3D ICs..pdf (1.45 MB , 下载次数: 35 )
abbr_d17c147a4e7bc38bbe2e9f2a7c8b6370.pdf (898.85 KB , 下载次数: 12 )
Thermal modeling, characterization and management of on-chip networks..pdf (552.36 KB , 下载次数: 13 )
Thermal Monitoring Mechanisms for Chip Multiprocessors..pdf (1.95 MB , 下载次数: 45 )
Thermal Via Insertion and Thermally Aware Routing in 3D ICs.pdf (822.75 KB , 下载次数: 17 )
Thermal vs Energy Optimization for DVFS-Enabled Processors in Embedded Systems..pdf (239.36 KB , 下载次数: 14 )
THERMAL-AWARE MAPPING AND PLACEMENT FOR 3-D NoC DESIGNS.PDF (3.05 MB , 下载次数: 20 )
Thermal-Aware Task Scheduling for 3D Multicore Processors..pdf (1.73 MB , 下载次数: 26 )
Three-Dimensional Chip-Multiprocessor Run-Time Thermal Management..pdf (737 KB , 下载次数: 12 )
Three-Dimensional Multiprocessor System-on-Chip Thermal Optimization..pdf (275.2 KB , 下载次数: 15 )
ThresHot An Aggressive Task Scheduling Approach in CMP Thermal Design..pdf (242.87 KB , 下载次数: 12 )
Tightly-Coupled Multi-Layer Topologies for 3-D NoCs.PDF (290.52 KB , 下载次数: 17 )
abbr_76db8026d11a1798a947afacc6a3a582.pdf (294.12 KB , 下载次数: 10 )
Traffic- and Thermal-Aware Run-Time Thermal Management Scheme for 3D NoC Systems.pdf (1.51 MB , 下载次数: 22 )
abbr_6769d6914b11a7818a4e2eb680a5f8a9.pdf (865.2 KB , 下载次数: 14 )
Vertical Interconnects Squeezing in Symmetric 3D Mesh Network-on-Chip..pdf (231.85 KB , 下载次数: 10 )
Voltage-Frequency Planning for Thermal-Aware, Low-Power Design of Regular 3-D NoCs..pdf (469.15 KB , 下载次数: 12 )
XNoTs Crossbar-Connected Multi-Layer Topologies for 3-D NoCs..pdf (231.23 KB , 下载次数: 14 )
 楼主| 发表于 2012-11-25 08:55:10 | 显示全部楼层
回复 2# zhq415758192
    有标题你们可以自己选择要哪些文档啊,,,
    1块钱1篇  还骗钱啊?!
发表于 2013-1-3 16:43:41 | 显示全部楼层
GOOD,3X
 楼主| 发表于 2013-1-3 21:17:46 | 显示全部楼层
回复 4# nico0811
    很好的资料。。。
发表于 2013-4-4 18:28:48 | 显示全部楼层
都是骗人的,这些东西没上面用
 楼主| 发表于 2013-4-5 09:35:06 | 显示全部楼层
回复 6# y23angchen
    都是热门的东西   关键看你有没有兴趣
发表于 2013-5-9 15:02:39 | 显示全部楼层
good data
发表于 2013-5-10 16:32:46 | 显示全部楼层
谢谢,下载了看一下
 楼主| 发表于 2013-6-15 10:53:36 | 显示全部楼层
回复 8# eekevin25
   那肯定的!
发表于 2013-7-30 21:14:48 | 显示全部楼层
bucuo,谢谢
GMT+8, 2025-12-24 03:35 , Processed in 0.022705 second(s), 5 queries , Gzip On, Redis On.
