查看: 2264|回复: 0
[招聘] NO.78-Senior Backend Engineer(Shanghai)
发表于 2012-11-20 11:07:09 | 显示全部楼层 |阅读模式
Position Description:
As a senior backend engineer, you need to have had years hands on experience in Cadence/Synopsys front-end and Static Timing Analysis flow.
You will be responsible for ensuring customer success through various design serve participation and practices. You would need to report / interface with customer for project status, and to consult / feedback to customer with any design implementation difficulty and plans.
Qualifications:
1. 3+ years hands on experiences in one or more of following tools - DC, PT, PT-Si, startRC-xt. etc
2. Experience in successfully tapeout 5+ projects from customer RTL/GTECH hands off to GDS tapeout.
3. Experience in 130 nm tapeout is must (90 & 65 nm and or beyond front-end design flow is prefered), be familiar with RTL coding style, clock definition (clock generate module clarification), static timing analysis, post-layout simulation, power analysis, etc.
4. Good customer interfaces skills - to interact with customer for any design related issue. Help sales team to solicit and promote the technical idea.
5. Good written and verbal communication in Mandarins and English;; Excellent interpersonal and team work skills
Required Education:
Demonstrated leadership experience of a design engineering team is required. Minimum requirements are: 6 years with with BSEE. or equivalent; 4years with MSEE
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
GMT+8, 2025-12-28 13:05 , Processed in 0.014510 second(s), 6 queries , Gzip On, Redis On.
