楼主: huang_cq
[求助] 怎么把veriloga载入HspiceD中仿真
发表于 2022-12-7 13:54:54 | 显示全部楼层
xinleiye 发表于 2016-4-12 16:31
IC51里面可以这样设置:首先Q属性àCDF Parameter of viewàdata vss vdd(声明电源地的具体电平值以及数据 ...
这个很有用,在hspcieD中不能生成网表的时候,可以用着去更改view list的东西
感谢
发表于 2023-10-30 14:56:30 | 显示全部楼层
xd_HR 发表于 2020-11-25 21:10
如图所示,在.sp文件中.hdl  ~
兄可以让我看一下opamp的va嘛
发表于 2024-5-30 13:50:04 | 显示全部楼层
感谢
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
      ...unsuccessful.  修改了 但是还是会有这个错误
发表于 2024-5-30 14:06:54 | 显示全部楼层
hspiceD需要在ADEàsetupàenvironment的的view list里添加上veriloga---这一步已经做了
hspiceD仿真veriloga  还是出现ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
      ...unsuccessful.这个错误
使用spec 仿真器没事  求指点一下
发表于 2024-5-30 14:09:45 | 显示全部楼层
使用spec 仿真器没事  求指点一下
GMT+8, 2025-12-15 20:01 , Processed in 0.013533 second(s), 3 queries , Gzip On, Redis On.
