查看: 7318|回复: 4
cadence ic610安装问题
发表于 2012-11-1 14:28:03 | 显示全部楼层 |阅读模式
我是在rehl5下安装的cadence ic610
[gongliwei@bogon ~]$ /home/eda/IC610/tools/bin/lmgrd -c /home/eda/IC610/share/license/license.dat
报错:而且会一直跑
23:10:15 (cdslmd) tw01          tw02
23:10:15 (cdslmd)
23:10:15 (cdslmd) All FEATURE lines for cdslmd behave like INCREMENT lines
23:10:15 (cdslmd)
23:10:15 (cdslmd) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7:2 "No such file or directory"))
23:10:15 (cdslmd) EXITING DUE TO SIGNAL 37
23:10:15 ((lmgrd)) Loop info: MT:0 VD_HB:0 reset:0clients:0fd's:0
23:10:15 (lmgrd) cdslmd exited with status 37 (Communications error)
23:10:15 (lmgrd) Please correct problem and restart daemons
再次运行:[gongliwei@bogon ~]$ /home/eda/IC610/tools/bin/lmgrd -c /home/eda/IC610/share/license/license.dat
报错:23:16:52 (lmgrd) The TCP port number in the license, 5280, is already in use.
23:16:52 (lmgrd) Possible causes:
23:16:52 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
23:16:52 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
23:16:52 (lmgrd)    3) Another process is using this port number (unlikely).
23:16:52 (lmgrd) Solutions:
23:16:52 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
23:16:52 (lmgrd)       license are not running.
23:16:52 (lmgrd)    2) You may have to wait for the OS to clear this port.
23:16:52 (lmgrd) Retrying for about 5 more minutes
开启ic610时:icfb&(cadence对话框闪一下就消失了)
 楼主| 发表于 2012-11-3 18:44:52 | 显示全部楼层
同志们,帮帮忙啊
发表于 2012-12-4 22:57:35 | 显示全部楼层
你问题解决了吗?我也出现同样问题!就一直停在启动界面上!
发表于 2013-3-31 15:08:40 | 显示全部楼层
我重装的时候居然也发现了。回来发现时这样(还是就用系统默认的主机名,改来改去麻烦)
0.        安装时把主机名设为yulong
1.        /etc/sysconfig/network
更改 HOSTNAME=localhost
2.        /etc/hosts
确认localhost localhost.localdomain
3.        输入 hostname localhost
4.        确认输入localhost,返回localhost.localdomain
5.        重启
发表于 2016-3-9 12:33:58 | 显示全部楼层
遇到同样的问题,请问怎么解决?
GMT+8, 2025-12-17 14:52 , Processed in 0.018438 second(s), 7 queries , Gzip On, Redis On.
