查看: 8163|回复: 6
[资料] The TCP port number in the license, 1717, is already in use.
发表于 2012-10-28 08:55:30 | 显示全部楼层 |阅读模式
21:46:05 (lmgrd)   Please Note:
21:46:05 (lmgrd)
21:46:05 (lmgrd)   This log is intended for debug purposes only.
21:46:05 (lmgrd)   In order to capture accurate license
21:46:05 (lmgrd)   usage data into an organized repository,
21:46:05 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
21:46:05 (lmgrd)   software license administration  solution,
21:46:05 (lmgrd)   FLEXnet Manager, to  readily gain visibility
21:46:05 (lmgrd)   into license usage data and to create
21:46:05 (lmgrd)   insightful reports on critical information like
21:46:05 (lmgrd)   license availability and usage. FLEXnet Manager
21:46:05 (lmgrd)   can be fully automated to run these reports on
21:46:05 (lmgrd)   schedule and can be used to track license
21:46:05 (lmgrd)   servers and usage across a heterogeneous
21:46:05 (lmgrd)   network of servers including Windows NT, Linux
21:46:05 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
21:46:05 (lmgrd)   www.acresso.com for more details on how to
21:46:05 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
21:46:05 (lmgrd)   for your enterprise.
21:46:05 (lmgrd)
21:46:05 (lmgrd) -----------------------------------------------
21:46:05 (lmgrd)
21:46:05 (lmgrd)
21:46:05 (lmgrd) The TCP port number in the license, 1717, is already in use.
21:46:05 (lmgrd) Possible causes:
21:46:05 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
21:46:05 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
21:46:05 (lmgrd)    3) Another process is using this port number (unlikely).
21:46:05 (lmgrd) Solutions:
21:46:05 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
21:46:05 (lmgrd)       license are not running.
21:46:05 (lmgrd)    2) You may have to wait for the OS to clear this port.
21:46:05 (lmgrd) Retrying for about 5 more minutes
那位大侠知道怎么解决这个问题,不胜感激!改了port也没用啊!
 楼主| 发表于 2012-10-28 10:20:14 | 显示全部楼层
自己顶一下!
发表于 2013-7-30 17:41:09 | 显示全部楼层
楼主解决了吗??我也遇到同样的情况
 楼主| 发表于 2013-7-30 19:46:43 | 显示全部楼层
回复 3# liangdy013
   我也没查出原因,后来重新装了一遍好了
发表于 2020-11-23 15:22:07 | 显示全部楼层
刚解决了,建议关闭防火墙
发表于 2021-12-2 15:27:27 | 显示全部楼层
alafakeyou 发表于 2020-11-23 15:22
刚解决了,建议关闭防火墙
请问您怎么解决的
发表于 2022-1-18 22:49:01 | 显示全部楼层
求解!
GMT+8, 2025-12-25 06:19 , Processed in 0.019430 second(s), 7 queries , Gzip On, Redis On.
