查看: 13489|回复: 19
[求助] ICC里如何移除dont touch 属性
发表于 2012-10-18 09:13:34 | 显示全部楼层 |阅读模式
RT
在ICC里出现了几个net ,属性为dont touch,想将其dont touch属性去掉,对其优化。请问各位大大,怎么去掉呢?
发表于 2012-10-18 09:17:06 | 显示全部楼层
remove_attribute [] dont_touch
 楼主| 发表于 2012-10-18 09:25:28 | 显示全部楼层
回复 2# michaelll
试了,好像不行
这是出现的违例情况。
max fanout
RSTB                        12.00        1084.00       -1072.00  (VIOLATED)
   CLOCK_OUT_G3B3I17 (dont_touch)
                               12.00          67.00         -55.00  (VIOLATED)
   CLOCK_OUT_G3B3I16 (dont_touch)
                               12.00          65.00         -53.00  (VIOLATED)
   CLOCK_OUT_G3B3I1 (dont_touch)
                               12.00          54.00         -42.00  (VIOLATED)
   UVR_CS_LCOS2012_GAMMA_CORRECTION/CLOCK_OUT_G3B3I18 (dont_touch)
                               12.00          50.00         -38.00  (VIOLATED)
   CLOCK_OUT_G3B3I13 (dont_touch)
                               12.00          49.00         -37.00  (VIOLATED)
   CLOCK_OUT_G3B3I19 (dont_touch)
                               12.00          44.00         -32.00  (VIOLATED)
   UVR_CS_LCOS2012_S2P/PCLK_G1B6I1 (dont_touch)
   CLOCK_OUT_G3B3I15 (dont_touch)
                               12.00          43.00         -31.00  (VIOLATED)
   CLOCK_OUT_G3B3I5 (dont_touch)
                               12.00          42.00         -30.00  (VIOLATED)
   CLOCK_OUT_G3B3I9 (dont_touch)
用了命令remove_attribute [get_nets CLOCK_OUT_*] dont_touch 之后,报告下面错误
Warning: Attribute 'dont_touch' does not exist on net 'CLOCK_OUT_G3B3I13'. (UID-101)
Error: Attribute 'dont_touch' on class net cannot be removed. (MWUI-035)
Warning: Attribute 'dont_touch' does not exist on net 'CLOCK_OUT_G3B3I14'. (UID-101)
Warning: Attribute 'dont_touch' does not exist on net 'CLOCK_OUT_G3B3I9'. (UID-101)
Warning: Attribute 'dont_touch' does not exist on net 'CLOCK_OUT_G3B2I1'. (UID-101)
Warning: Attribute 'dont_touch' does not exist on net 'CLOCK_OUT_G3B3I15'. (UID-101)
Warning: Attribute 'dont_touch' does not exist on net 'CLOCK_OUT_G3B3I2'. (UID-101)
Warning: Attribute 'dont_touch' does not exist on net 'CLOCK_OUT_G3B3I19'. (UID-101)
命令应该没写错呀,怎么会报告这样的错误呢?
发表于 2012-10-18 09:49:01 | 显示全部楼层
set_dont_touch xxx false
 楼主| 发表于 2012-10-18 09:57:51 | 显示全部楼层
回复 4# 陈涛
    版主,这个是设置attribute吧,
    刚刚试了,打set_dont_touch [get_nets CLOCK_OUT_*] false,再remove_attribute。
   还是不行!
发表于 2012-10-18 10:09:36 | 显示全部楼层
点选 CLOCK_OUT_G3B3I19, cntl-R打开它所以的属性,看看里面有什么fix,dont_touch等特殊的属性
发表于 2012-10-18 16:30:50 | 显示全部楼层
試試看這個吧.
mark_clock_tree
              -clock_trees name_or_source_pin_list
              -remove clock_synthesized
 楼主| 发表于 2012-10-19 10:49:25 | 显示全部楼层
回复 8# zhq415758192
    没有呀。
 楼主| 发表于 2012-10-19 10:58:29 | 显示全部楼层
设计中有两块IP,我把他设置成dont touch了,但sdc没有看见这个设置呀,怎么ICC可以发现呢,现在在ICC想把dont  touch去掉,对时钟进行优化。可是老去不掉,快崩溃了
 楼主| 发表于 2012-10-19 15:22:39 | 显示全部楼层
自己顶起
GMT+8, 2025-9-17 05:27 , Processed in 0.019605 second(s), 6 queries , Gzip On, Redis On.
