查看: 4205|回复: 4
[求助] 高手,请问VHDL 的 WHEL 怎么用才可以?
发表于 2012-10-17 08:24:56 | 显示全部楼层 |阅读模式
library ieee;
        use ieee.std_logic_1164.all;
        use ieee.std_logic_arith.all;
        use ieee.std_logic_unsigned.all;
ENTITY Controller IS
   PORT (
         CLOCK                   : in        std_logic;
         TSCLK                   : out       std_logic;
         RESET_N                 : in        std_logic
   END Controller;
ARCHITECTURE RTL OF Controller IS
type SDCNT_type is   (A,B,C,D,E,F,G);
signal    SDCNT : SDCNT_type;
signal    SCLK  : std_logic;
begin
  TSCLK <= not CLOCK WHEN  (SCLK or ((SDCNT >= B) and (SDCNT <= G))) = '1' ELSE '0';  <--ERROR
Error (10327): VHDL error at Controller.vhd(56): can't determine definition of operator ""or"" -- found 0 possible definitions
  TSCLK <= not CLOCK WHEN (SCLK or ((SDCNT >= B) and (SDCNT <= G)))  ELSE '0'; <--ERROR
Error (10476): VHDL error at Controller.vhd(56): type of identifier "SCLK" does not agree with its usage as "boolean" type
.....??????????????????.....不知道怎么改?
因为 SDCNT 为自定型态
发表于 2012-10-17 13:36:35 | 显示全部楼层
SDCNT 是状态,怎么可能比较大小。
 楼主| 发表于 2012-10-17 16:36:23 | 显示全部楼层
谢谢说明,没注意到,,改这样又错了,不知道又错什么?
use ieee.numeric_std.all;
signal    INDEX           : std_logic_vector(5 downto 0);
case to_integer(unsigned(INDEX)) is
when 1 =>
when 2 =>
more than one Use Clause imports a declaration of simple name "unsigned" -- none of the declarations are directly visible
 楼主| 发表于 2012-10-17 17:03:46 | 显示全部楼层
回复 3# keyway
case to_integer(INDEX) is
when 1 =>
when 2 =>
can't determine type of object at or near identifier "to_integer" -- found 0 possible types
这样也不行....
 楼主| 发表于 2012-10-17 20:36:41 | 显示全部楼层
自己的問題全部都解決了,看來 VHDL 實在在型態上弄的好複雜..
GMT+8, 2025-12-22 02:54 , Processed in 0.017570 second(s), 5 queries , Gzip On, Redis On.
