查看: 4422|回复: 5
[求助] uvm中sequence和sequencer注册咨询!!
发表于 2012-10-10 23:31:33 | 显示全部楼层 |阅读模式
在uvm中,一般来说,对于sequenc和sequencer有两种注册方法:
1,sequence:·uvm_object_utils(sequence)
     sequencer:·uvm_component_utils(sequencer)
2,sequence:·uvm_sequence_utils(sequence)
     sequencer:·uvm_sequencer_utils(sequencer,sequence)
这两种方法有什么区别,各有什么优点,请高手指点呢?
发表于 2012-10-12 02:54:12 | 显示全部楼层
前者应该还缺少一个sequence和sequencer的对应处理,记得是一个带后缀lib的宏。曾经在国外论坛看到说不建议用第二种方式注册序列。
 楼主| 发表于 2012-10-13 10:49:50 | 显示全部楼层
    一般来看都是第一种注册,只是在别人的一个平台中看到了这种方式,又没有找到相关的资料,就问问高手了。谢谢!
发表于 2012-10-13 13:33:41 | 显示全部楼层
First Create a sequencer and register with sequencer utils `uvm_sequencer_utils(sequencer_name)
and now create a sequence and register that sequence with the factory and as well as the sequencer Lib
`uvm_sequence_utils(sequence_name,sequencer_name)
every sequencer by default wil have its own sequence library
when in the function new(); inside your sequencer use the macro......`uvm_update_sequence_lib_and_item
all the sequences registered with this sequencer will be updated automatically and the sequencer will know it and update internally in his sequence library
 楼主| 发表于 2012-10-14 11:11:46 | 显示全部楼层
回复 4# shoaibsaiufuddi
    3Q!!
发表于 2013-5-19 21:23:36 | 显示全部楼层
受教了
GMT+8, 2025-12-26 11:57 , Processed in 0.026135 second(s), 5 queries , Gzip On, Redis On.
