查看: 10049|回复: 11
ic615里面包含了哪些软件呢?
发表于 2012-10-9 15:22:04 | 显示全部楼层 |阅读模式
最近要用到encounter,abstract,virtuso这些,用这些为关键字搜索了挺久,没找到然后发现ic610,ic615里面好像集成了一些。
所以,我怎么才能知道ic61x,mmsim这些里面,到底有哪些部分呢?
小白一个,以前直接用学校机房配置好的,现在自己搞,就糊涂了。大神勿拍……
发表于 2012-10-9 16:53:51 | 显示全部楼层
Products included in Release- IC615
Product #        Product Name        Version
111        Cadence(R) Design Framework II        6.1.5
117        Cadence Framework Integration Runtime Option        6.1.5
12141        Cadence(R) Design Framework Integrator's Toolkit        6.1.5
206        Virtuoso(R) Simulation Environment        6.1.5
21060        Virtuoso(R) Schematic VHDL Interface        6.1.5
21400        Virtuoso(R) Schematic Editor Verilog(R) Interface        6.1.5
276        Virtuoso(R) Schematic Editor HSPICE Interface        6.1.5
32100        Virtuoso(R) Analog Oasis Run-Time Option        6.1.5
32101        Cadence(R) OASIS for RFDE        6.1.5
32102        Virtuoso OASIS Integration Toolbox        6.1.5
32103        Virtuoso Waveform Reader Toolbox        6.1.5
32760        Virtuoso(R) Analog HSPICE Interface Option        6.1.5
3300        Virtuoso(R) Chip Assembly Router        11.3
365        Dracula(R) Graphical User Interface        6.1.5
5100        Virtuoso(R) Layout Migrate        6.1.5
681        Cadence(R) RC Network Reducer Option        3.0
70000        Virtuoso(R) AMS Designer Environment        6.1.5
70110        Dracula(R) Design Rule Checker        4.9
70120        Dracula(R) Layout Vs. Schematic Verifier        4.9
70130        Dracula(R) Parasitic Extractor        4.9
70510        Dracula(R) Physical Verification Suite        4.9
70520        Dracula(R) Physical Verification and Extraction Suite        4.9
71110        Diva(R) Design Rule Checker        4.4.5
71120        Diva(R) Layout Vs. Schematic Verifier        4.4.5
71130        Diva(R) Parasitic Extractor        4.4.5
71510        Diva(R) Physical Verification Suite        4.4.5
71520        Diva(R) Physical Verification and Extraction Suite        4.4.5
900        Cadence(R) SKILL Development Environment        6.1.5
940        Virtuoso(R) EDIF 200 Reader        6.1.5
945        Virtuoso(R) EDIF 200 Writer        6.1.5
95100        Virtuoso(R) Schematic Editor L        6.1.5
95115        Virtuoso(R) Schematic Editor XL        6.1.5
95200        Virtuoso(R) Analog Design Environment L        6.1.5
95210        Virtuoso(R) Analog Design Environment XL        6.1.5
95220        Virtuoso(R) Analog Design Environment - GXL        6.1.5
95222        Token Control for Virtuoso® Analog Design Environment - GXL        6.1.5
95255        Virtuoso(R) Visualization & Analysis XL        6.1.5
95300        Virtuoso(R) Layout Suite L        6.1.5
95310        Virtuoso(R) Layout Suite XL        6.1.5
95311        Virtuoso(R) DFM Option        6.1.5
95320        Virtuoso(R) Layout Suite - GXL        6.1.5
95321        Virtuoso(R) Layout Suite - GXL        6.1.5
95322        Token Control for Virtuoso® Layout Suite - GXL        6.1.5
95400        Virtuoso Constraint API Run-Time Option        6.1.5
95401        Cadence Constraint Integration Toolbox        6.1.5
VPS100        Virtuoso(R) Power System L        6.1.5
VPS200        Virtuoso(R) Power System XL
 楼主| 发表于 2012-10-11 10:04:18 | 显示全部楼层
回复 2# liude19832006
   你好,这个在哪能查到呢?615里面是不是包含了610的东西呢?
发表于 2012-10-11 18:04:06 | 显示全部楼层
回复 3# 284294022
   当然包含了。这是官方网站上面IC615中的内容。
发表于 2012-10-12 06:38:45 | 显示全部楼层
Good to know.
发表于 2012-12-31 13:38:28 | 显示全部楼层
要是有个网盘的,该多好!
发表于 2013-1-7 19:00:27 | 显示全部楼层
感谢lz啊
发表于 2013-2-3 13:19:38 | 显示全部楼层
回复 6# cxhgdut
是啊,我也想找到网盘可以下载。。。
发表于 2013-2-6 07:58:23 | 显示全部楼层
感谢2楼的解答
发表于 2014-4-29 00:23:41 | 显示全部楼层
长知识~
GMT+8, 2025-10-31 20:36 , Processed in 0.019482 second(s), 5 queries , Gzip On, Redis On.
