查看: 3530|回复: 5
有人在用Magellan么?高人指点一下吧
发表于 2012-10-9 12:21:37 | 显示全部楼层 |阅读模式
我是Magellan的新手,安装完了进行安装测试时报错,但是VCS和DC运行完好:
请高人指点!
======================= M A G E L L A N Install Test ============================
>> Setting MG_HOME to /tools/synopsys/magellan201209
               Magellan (mgsh)
  Version: G-2012.09 (linux - Aug 29, 2012)
  Copyright(c)1988-2012 by Synopsys, Inc.
            ALL RIGHTS RESERVED
This program is proprietary and confidential
information of Synopsys, Inc. and may be used
and disclosed only as authorized in a license
agreement controlling such use and disclosure.
  Client Server Name: localhost.localdomain
               Alias: localhost
             Address: 127.0.0.1
                Port: 5555
   Explore Server on: localhost
     Build Server on: localhost
       Run Server on: localhost
>>>>>>>>>>>>>>>>>>>>>>>>>> Checking Environment Variables <<<<<<<<<<<<<<<<<<<<<<<<<<<
-- checking: SYNOPSYS
    > /tools/synopsys/dc201003
-- checking: MG_HOME
    > /tools/synopsys/magellan201209
-- checking: VCS_HOME
    > /tools/synopsys/vcs1112
-- checking: SNPSLMD_LICENSE_FILE
    > 27000@localhost.localdomain
>>>>>>>>>>>>>>>>>>>>> Checking Required License Feature Tokens <<<<<<<<<<<<<<<<<<<<<<
** All Licenses are accessible!
>>>>>>>>>>>>>>>>>>>>>>> Testing Property and Coverage run <<<<<<<<<<<<<<<<<<<<<<<<<<<
>>> Start Session: ses3
----- Initial VCS Compile (12:24:02 PM - Oct 09) -----
*** Error: (HVB-035)
     Simulation compile failed.
*** Information: (HVSH-350)
     Information about the build has been added to the build log.
     Use 'stat -build' to view it.
*** Error: (HVB-502)
     Simulator compile for HDL analysis failed.
     See compilation output above.
*** Information: (HVSH-408)
     Use the 'list_session_results' command to get detailed results on all property/coverage modules.
*** Error: (HVSH-353)
     Build (session: ses3) *failed* at time (12:24:04 PM - Oct 09).
     Use 'stat -build' command to see results.
     CPU Time     =     0.56 (s)
     Elapsed Time =     9.81 (s)
     Peak Memory  =    63.00 (mb)
     Max  Memory  =    63.00 (mb)
*** Error: Build Failed!
********************************** INSTALL FAILED! **********************************
Shutting down...
 楼主| 发表于 2012-10-10 17:01:26 | 显示全部楼层
难道没有人用这个软件么??
发表于 2012-10-10 18:32:22 | 显示全部楼层
总得先上传,才能有人帮你分析吧。
发表于 2012-10-13 10:40:37 | 显示全部楼层
I have got this problem too!
发表于 2013-2-24 21:32:00 | 显示全部楼层
回复 1# 飞扬紫百合
   这个问题,可能是g++ 的版本问题,尝试以下几个版本g++-3.4.6, g++-4.2.2 and g++-4.5.2.
发表于 2016-9-30 14:32:33 | 显示全部楼层
回复 5# snk88
   求助楼主和5楼,我现在遇到这个问题,不知道你们知道怎么解决吗?
  System Clock Period = 100
*** Information: (HVB-929)
     Generating simulation reset state for optimization
*** Information: (HVB-930)
     Finished generating simulation reset state
*** Information: (HVOR-403)
     Comparing reset states for equivalence
*** Error: (HV-053)
     Internal Error: Failed to connect a socket to host:localhost AppErr:connecting to compute server SysErr:Connection refused
     (Contact Synopsys Support)
*** Error: (HV-053)
*** Error: (HV-053)
GMT+8, 2025-12-20 18:11 , Processed in 0.026558 second(s), 7 queries , Gzip On, Redis On.
