查看: 3495|回复: 5
Install only Vivado-HLS (seperate it form ISE's installation)
发表于 2012-9-30 22:59:37 | 显示全部楼层 |阅读模式
As you know, Xilinx has merged Vivado HLS with ISE and Plan Ahead tools. During the installation you do not have any choice for installing only the Vivado HLS so for doing that, delete only the below folders from the installation directory and nothing else.
codesourcery
edk
ise
labtools
planahead
sdk
sysgen
vivado
Then run the installation. No errors are reported during the installation. Vivado needs only 1 GigaByte but the whole installation needs about 16 GigaByte. After that you can use snk's posted license for the HLS.
发表于 2012-10-1 11:39:10 | 显示全部楼层
为什么要删除啊啊,现在的硬盘都足够大吧
发表于 2012-10-14 22:17:15 | 显示全部楼层
kankan
发表于 2012-10-16 09:18:33 | 显示全部楼层
Vivado_HLS是需要單獨的License的。
发表于 2013-4-30 18:42:24 | 显示全部楼层
thanks
发表于 2013-4-30 21:39:27 | 显示全部楼层
写得不错。
GMT+8, 2025-12-29 02:43 , Processed in 0.019746 second(s), 7 queries , Gzip On, Redis On.
